Topic: external power servo problem (Read 2389 times) previous topic - next topic
ersod
I have 2 parallax continuous servos and i want to use an external power 4 AA batteries (= 6Volt). The problem is that i can't find a way to make it work with the arduino.
I read that i should connect the Gnd from batteries with the Gnd pin from arduino, but it doesn't work. Look my connections:
If i connect the servos this way, it only begin the one and with low speed(in my code i have both of them in full speed). If i connect only one servo it works, but with 2 NO.With 2 servos it has really strange behaviour, when i disconnect the signal wire from one also stops the other
Is it hardware problem (burned servo, connection)? Maybe software (my code is wrong? but if i connect only one each time works) ?
Thanks !!!
CrossRoads
Post some more stuff:  your code, a link to the servo, your schematic.
ersod
#2
Feb 24, 2011, 06:53 pm Last Edit: Feb 24, 2011, 07:00 pm by ersod Reason: 1
datasheet for the servo
http://www.parallax.com/Portals/0/Downloads/docs/prod/motors/900-00008-CRServo-v2.1.pdf
and my code
//simple code to rotate one servo right and one servo left in full speed
int servoPin1 = 6;
int servoPin2 = 7;
pinMode(servoPin1,OUTPUT);
pinMode(servoPin2,OUTPUT);
digitalWrite(servoPin1,HIGH);
delayMicroseconds(1200);
digitalWrite(servoPin1,LOW);
delay(20); // 20ms
digitalWrite(servoPin2,HIGH);
delayMicroseconds(1800);
digitalWrite(servoPin2,LOW);
delay(20); // 20ms
schematic ??
i just connect the servos to the breadboard in my first  post
retrolefty
Your wiring setup looks correct to me. However your software is a problem. You really should be using a servo library for your code, that way you just program changes and the library handles the continous updating to the servo control signal.
http://arduino.cc/en/Reference/Servo
Lefty
CrossRoads
So you have the effect of a 1.2mS high pulse and 41.8mS off for one, and 1.8mS pulse and 41.2mS off for the other.
Reading the datasheet, looks like you have an extra delay(20) in your code, at a  minimum.
ersod
@retrolefty when i search i found that code for continuous rotation for arduino and so i used it. I knew about the servo library but i don't know how works. I will try again
@KE7GKP the max voltage for each servo is 6 Volt. My batteries are new and since i have seen many constructions with 4 AA batteries( 6 Volt) and 3 servos , i believe that it should work.
retrolefty
The servo library will allow you just to only concern yourself with when you want to send a specific usec command value to each servo, the library will handle all the timing stuff for you.
Lefty
ersod
#7
Feb 24, 2011, 07:21 pm Last Edit: Feb 24, 2011, 07:55 pm by ersod Reason: 1
is this code correct ? I try with this but nothing works (edit:Look next post)
#include <Servo.h>
Servo myservo1;
Servo myservo2;
 myservo1.attach(6);
 myservo2.attach(7);
   myservo1.writeMicroseconds(1.5);
   myservo2.writeMicroseconds(1.5);
   myservo1.writeMicroseconds(1.2);
   myservo2.writeMicroseconds(1.8);
ersod
Guys i believe that one servo is burned
I found a standard servo this time and i put on the breadboard both one continuous and one standard servo and i use servo library.
Both of them works. Then i put the second continuous servo in the continuous servo that it works and didn't begin.( i hear a sound  for a second like it going to begin but it doesn't begin)
I would like to ask you also 1 more question.
i want to put 3 servo in my construction, how to power them safe ( i don't want to burn one more)?
retrolefty
You can't use floating point numbers (ones with decimal points) in the servo command. It's expecting a usec long value:
should be:
  myservo1.writeMicroseconds(1500);
  myservo2.writeMicroseconds(1500);
Servos value should stay in the 1000 to 2000 usec range.
Lefty
ersod
Yes but with  1800 and 1200 it turns REALLY slowly, hardly you see it turn
retrolefty
Well 1000 should give max speed in one direction, 2000 max speed in the other direction, and somewhere around 1500 should stop turning.
Lefty
ersod
first i like to thank you for your answers and sorry if I become tedious.
I read some things and i understand that maybe i need to calibrate my servo(so for this reason @retrolefty you gave me other numbers than the datasheet) ?. I use writeMicroseconds(1500) and the servo turns in a speed. I open my servo and i find a trimmer. I turn it still it stop. I find the center(1500 says the datasheet) for the servo , right ?
Now when i put 1800 and 1200 it works as it says in the datasheet.
But if i put for example 2300 it turns faster. Is this safe ? (since datasheet says to send pulses 1200 - 1800 only )  ? and since i calibrate my servo these values are not allowed?
zoomkat
Below is some code I've used for testing two continous rotation servos via the serial monitor.
// zoomkat 11-22-10 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(6);  //the pin for the servo control
  myservo2.attach(7);
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
      Serial.println(readString); //see what was received
      // expect a string like 07002100 containing the two servo positions
      servo1 = readString.substring(0, 4); //get the first four characters
      servo2 = readString.substring(4, 8); //get the next four characters
      Serial.println(servo1);  //print to serial monitor to see results
      Serial.println(servo2);
      int n1; //declare as number
      int n2;
      char carray1[6]; //magic needed to convert string to a number
      servo1.toCharArray(carray1, sizeof(carray1));
      n1 = atoi(carray1);
      char carray2[6];
      servo2.toCharArray(carray2, sizeof(carray2));
      n2 = atoi(carray2);
      myservo1.writeMicroseconds(n1); //set servo position
      myservo2.writeMicroseconds(n2);
    readString="";
