Topic: Please check my circuit for errors.. (Read 3314 times) previous topic - next topic
jayakrishnan
Hey im building this line follower from scratch so im not directly using an arduino board, im building a pcb using atmega328... there is an l293D motor driver, infra red sensors, voltage regulator ..
sensor output goes into the analog input and motor driver input pins go into the digital ports.
Im a total noob at this, so kindly help me :)
retrolefty
Sorry my machine won't read a .sch file.
Lefty
westfw
It looks like you have a LOT of wires that are not actually connected to the pins they look like they are connected to.  You probably started with the Arduino reference schematic, which has several components "off grid" making them difficult to connect to.  Use the "electrical rule check" (exclamation point in yellow circle) and fix (or at least understand) each of the errors and warnings that it shows.
You can move an off-grid component back onto the default grid by holding down CTRL when you pick it up in a "move" command.  Otherwise, "move" wil keep it at the same offset from the grid that it was originally placed.
Graynomad
No obvioius problem that I can see but I know nothing about the 293.
I do see some things like GNDs that don't appear to be connected.
One question, how are you going to program the chip?
BTW posting the schematic as a PDF or JPG might get you more viewers, not eveyone uses Eagle.
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
westfw
Oh yeah; just checked.  On the L293D, VCC1 is a "logic" supply and should be connected to your +5V rail.  VCC2 is the motor power with the separate connection.  The "EN" inputs should be tied to +5V rather than VCC2 (though I can't find an actual spec for the EN input voltages...)
jayakrishnan
Quote
Wont that automatically be connected once i switch it to board? connecting every gnd in the schematic would make it look crowded right?
Quote
Oh thanks , i shall rectify that..
Quote
im sorry i didnt really get you, besides that my CTRL key wont work :D
and heres the original circuit in .jpg format. thanks everyone :)
Graynomad
Quote
In general you have to define EVERY required connection in the design, which you pretty much have. It just seemed to me that a couple of them may not be properly connected and need checking. If they aren't they won't get connected on the PCB either.
Another possible dodgy connection is pin 4 on the mega and the GND connection on the middle opto and probably many more as westfw pointed out.
Also, as I said, how are you going to program the chip?
______
Rob
jayakrishnan
Quote
I have an arduino board with me, so i could program the atmega328 using the board and then use it in this circuit.. That would work, right?
Graynomad
Quote
Yes that will work, it gets a bit annoying if you have to do it 100 times though. You can use your other Arduino as a programmer but I've not done that so can't advise.
If you have to do your development with the board (and chip) in the bot I'd add provision for an FTDI cable or something so you can make code changes easily, and use a chip with a bootloader installed.
Believe me, you'll be changing your code a 1000 times until it "works" and then more when you make changes. You want the procedure to be as painless as possible.
______
Rob
jayakrishnan
Quote
I thought i could experiment first with my arduino board ,making all the connections and program it, after then plug it back into my pcb....
heres the edited circuit, it still shows a lot of errors(those yellow and red exclamation marks, i hope they are not so serious).....
westfw
Quote
Many were serious in the last version of the .SCH you posted.  Essentially all of the "Net XXX overlaps PIN" warnings are indications of a drawing that looks ok but does not actually have a connection where you think it does.  You can ignore the "part xxx does not have value." warnings, though.
Khalid
check this:)
http://www.david-laserscanner.com/forum/viewtopic.php?f=9&t=2655
http://www.youtube.com/watch?v=OAGcEoj_yQ0
Simply...You can't afford me..
Author Of:
http://my-woodcarving.blogspot.com/
http://www.free3dscans.blogspot.com/
http://my-diysolarwind.blogspot.com/
Oops..some one gave me Karma...:)
jayakrishnan
Hey, using the same 5volt from the voltage regulator for 1.microcontroller 2.sensor circuit(4 IR led,photodiode pair) 3.logic supply for L293D 4.enabling 2 pins ON in the L293D , is that feasible?
khalid@ thanks for the video, i really appreciate it. But how is it connected with my circuit? :)
MarkT
Don't connect AREF to Vcc, it'll may be damaged.  Just have a decoupling cap to ground from this pin.
jayakrishnan
Quote
Just curious, why do we connect a cap there?
