Topic: Seeking full wave bridge rectifier with the lowest forward voltage drop... (Read 654 times) previous topic - next topic
holesflow
Experts,
Google searching with the right keywords doesn't match their algorithms well. Most everything I see is 1volt/leg, and I'm trying to charge a battery (powering a μC) with low-power AC from RF (think Qi/Energy harvesting, etc.). what Since the power demands are low, I'm hoping the possibility of using SMD will make more efficient alternatives possible.
Would you go 1/2 wave, having that make up for 1 less leg's loss?
Problem is, I can't even figure out how to search for such a critter.
Thoughts?
TIA!
"A wise man can learn more from a foolish question than a fool can learn from a wise answer". ~ Bruce Lee.
"If you drop it and it breaks, it was good." ~ Mr. William Lehr, my Electronics VoTech Teacher, on testing vacuum tubes. RIP
DaveEvans
6v6gt
Paul_KD7HB
SMD is only efficient for circuit board use. Before you go too far searching, what AC voltages are you using? What frequency? And what charging current? Germanium signal diodes may work well.
Paul
MasterT
Try "schottky diode rf detector" as your google search pattern.
MarkT
Schottky diodes or germanium diodes or back diodes have the lowest rectification loss.  For RF you need
a diode that's fast enough for the frequencies involved.
ted
google - free rf energy.
include youtube
What is your the RF source ?
holesflow
Thanks experts for the great ideas!
By the comments, I see I succeeded at being too concise. A friend asked me to investigate Qi charging, with him thinking about a "generator" pad under a mouse pad, and a rechargeable mouse with a receiver. Problem is, they are all too big COTS, as they are made for cell phones. They're cheap, but not small.
Being that coil size has a huge impact on received RF (albeit in the KHz range), I took a look at what makes up these receivers, and it ain't much. Just a rectifier and regulator, as far as I can see. I don't think I could lose more in a FW rectifier than gain by only rectifying 1/2 wave, but that is just a gut feeling, and it's based on low voltage assumptions, where higher voltage can take the 1vdc/diode loss no problem..
This is why I mentioned the N-Channel MOSFETs as rectifiers, with some spec sheets looking at well under 1/2 volt total forward voltage loss at lower voltage.
Does this help?
TIA!
ted
http://www.longrangelocators.com/forums/showthread.php?t=18464
Your transmitter, make as described then you can change diameter of the coil.
C2=22nF, VR1 = tune for resonance.
ted
http://vu2lvj.blogspot.ca/2013/11/a-passive-field-strength-meter.html
Your charger, doesn't need ANT1 and C1, instead C3 your battery, everything on right of C 3 - remove. L as in transmitter
holesflow
Thanks, Ted!
Funny that the comments to that post all claimed it was useless nonsense... :)
ted
TonyWilk
Synchronous Rectification
Sometimes called: Active Rectification
Yours,
  TonyWilk
