Topic: Problem in using touch capability in mcufriend 3.5 tft (Read 223 times) previous topic - next topic
jako_man
Hi guys
i have mcufriend tft 3.5 inch for mega .....
at the beginning , i have the common problem of displaying white screen but it is solved
now , i try to use the touch option but it does not respond at all !!
i have used the URTouch library example but it only displays on screen , not available to use touch
any help , please ??
david_prentice
The Mcufriend mega2560 3.5 inch shields should work with Bodmer's TFT_HX8357 library if you have a 16-bit ILI9481, ILI9486, HX8357B, HX8357C.
The Mcufriend mega2560 3.5 inch shields should work with UTFT library if you have a 16-bit ILI9481, ILI9486, R61581.
The Mcufriend mega2560 shields should work with URTouch library.
Many more controllers and interfaces will work with MCUFRIEND_kbv but you have to do some complex editing.   e.g. delete two slash characters.
Please tell us which controller and which library you are using.
If you spend 10 minutes preparing your question,   you get an accurate solution immediately.
David.
