Topic: How to scroll a graph pixel by pixel on LCD st7920 (Read 186 times) previous topic - next topic
JorgenC
When graph shall print to pixelpos 119 I want the graph to scroll one pixel left and put the last value in pos 119, but it always moves 8 pixels at a time with the last value as a 8-pixel line.
In the serial monitor I can see that there is a loop going 8 times with the values moving to  the left before the drawpixel command. Why this loop ? And how can I just take the first loop-values ??
I use a DHT22 sensor on pin 2 and the LCD in serial.
Code: [Select]
if (y == 119) {
    for (x = 9; x < 119; x++) {
      hum[x] = hum[x + 1];
      temp[x] = temp[x + 1];
      if (hum[x] > maxVal) {
        hum[x] = maxVal;
     // Serial.print (x) ; Serial.println(hum[x]);  Just to test
      u8g.drawPixel((x), (64 - hum[x] / 1.6));
      u8g.drawPixel((x), (64 - temp[x] / 1.6));
  else {
        hum[x] = maxVal;
      //Serial.print (x) ; Serial.println(hum[x]);
robtillaart
1) What I would consider is to implement a circular buffer for the measurements.
That way I never need to shift them. just update an index
2) I would allways draw the latest value at 119, that means always shift the whole screen
Code: [Select]
for (i=0...N-1)
   remove line[i]
   line[i] = line [i+1]
draw line 119
This way every new value is handled in an indentical manner.
no special cases to handle == shorter code  == easier to understand.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
JorgenC
#2
Mar 12, 2018, 02:53 pm Last Edit: Mar 12, 2018, 03:10 pm by JorgenC
Here is a picture of my graph. It draws pixels one by one and when it reaches the right edge of the frame (x pos 119) I want it to scroll one pixel left  and draw the next pixel at x_pos 119. The frame is at pos 120. First graph pixel is at pos 9.
robtillaart
Rob Tillaart
JorgenC
OK. Know nothing about circular buffer but, found an example sketch I shall try to use. Thanks!
JorgenC
I've solved my problem with  this library :#include <U8g2lib.h>
and this constructor with a frame buffer :
U8G2_ST7920_128X64_F_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* CS=*/ 10, /*
reset=*/ U8X8_PIN_NONE);
and I used this command :
 u8g2.clearBuffer();
  draw();
u8g2.sendBuffer();
