Topic: How to reduce or timeout the time for the Ethernet W5500 when server port down (Read 133 times) previous topic - next topic
paulfer
Hi Guys
I Have a C# app running on my server, it listens on Port 7214. And, I have an arduino sketch that connects to it monotonously and sends data through.
It works just fine when the server is up and the c# app is running.
And it time(s)out fine when I disconnect the ethernet cable or disable the network adapter and it reconnects just fine then.
BUT, when I turn off the c# app, the client.connect() takes 32 seconds to timeout.
I have tried the solutions in this post: https://forum.arduino.cc/index.php?topic=291088.0
But that doesn't help for when the port / app is down.
How do I check that the port isn't available or how do I timeout the w5500 ethernet client sooner?
Here is my code to connect:
Code: [Select]
client.stop();
  if (client.connect(server, 7214) == 1)
    Serial.println("Connected");
    for (int i = 0; i < MAXNUMBEROFMESSAGESINQUEUE; i++)
      if (Msg[i].senttoserver == 0 )
        wdt_reset();
        Msg[i].senttoserver = 1;
        Serial.print("Send to Server:"); Serial.println(i);
        client.print('u');
        client.print(unitID);
        client.println(Msg[i].contents);
    Serial.println("No connection");
Any ideas?
Regards
Paul
