Topic: Newbie LED chase sequence (Read 1 time) previous topic - next topic
frankhiggins
Hi all,
I have this code that uses a pushbutton to start a chase and I want to alter the end from all the LEDS going out at once to going off one at a time in a random manner. Could someone please give me some code or tell me what I need to write in order to make this happen.
// A chase controlled by a button
int Button=2; //button assigned to pin 2
int timer = 100; // The higher the number, the slower the timing.
int ledPins[] = {
3,4,5,6,7,8,9,10 }; // an array of pin numbers to which LEDs are attached
int pinCount = 8; // the number of pins (i.e. the length of the array)
pinMode(Button, INPUT);
int thisPin;
// the array elements are numbered from 0 to (pinCount - 1).
// use a for loop to initialize each pin as an output:
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(ledPins[thisPin], OUTPUT);
//turn LEDS on
while (digitalRead(Button)==HIGH);
//delay (10);
  Serial.println("LOW");
while (digitalRead(Button)==LOW)
  Serial.println("HIGH");
digitalWrite(ledPins[thisPin], HIGH);
delay(timer);
digitalWrite(ledPins[thisPin], LOW);
for (int thisPin = pinCount - 1; thisPin >= 0; thisPin--) {
delay(timer);
I thought it might be something like this but can't seem to piece it together to get it to work.
// switch them randomly on and off
int someNumber = 22;
for (int i = 0; i < someNumber; i++){
int thisPin = random(3,10);
if (random(1) == 1){ // random(1) returns 0 or 1, I hope
// Finally, switch them all off
Any help much appreciated.
many thanks,
Frank
Grumpy_Mike
Please use the # icon when posting code:-
Code: [Select]
This will work you need to put it in the right place. Before the last } in your loop() function is good.
jraskell
Don't cross post.  You posted this in the Programming forum as well.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
