Topic: NodeMCU - parts of void setup() are skipped (Read 265 times) previous topic - next topic
tuila
Mar 12, 2018, 10:51 pm Last Edit: Mar 13, 2018, 07:37 pm by tuila
So I have tried 5 different NodeMCU boards now. I have correctly added esp8266 library to board manager and download the USB software to upload sketches.
I am able to upload sketches onto these boards. However, it appears that void setup is not running properly. Here is the basic test code I am running that leads me to this conclusion:
Code: [Select]
   Serial.println("Test void setup");
  Serial.println("Test loop");
Check the attachments for what happens in the serial monitor.
Essentially, the void loop runs fine but the serial.println is skipped. When I hit the reset button, this line is printed next to some gibberish. I thought maybe I could work around this for my project that will utilize and ultrasonic sensor to upload data to a Blynk app.
But, when I tried running that code:
Code: [Select]
// D = 1/2 Ã-- T Ã-- C
const int ECHOPIN = 4;
const int TRIGPIN = 3;
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  Serial.println("Begin reading distance");
  digitalWrite(TRIGPIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);
  delayMicroseconds(10);
  // Distance calc
  float distance = pulseIn(ECHOPIN, HIGH);
  distance = distance/58;
  Serial.print(distance);
  Serial.println(" cm");
  delay(2000);
Nothing printed at all on the serial monitor (including loop print statements). That is a bad sign because I tested this on the Arduino Uno and it works fine. I do not think these boards are defective because this problem has repeated 4 times. Note I did not purchase 4 consecutive boards, I ordered the first two as a pair and thought maybe that brand had a bad batch. Then they sent me a replacement, after I had ordered another one from a different brand. Each has the exact same problem.
ieee488
#1
Mar 12, 2018, 11:03 pm Last Edit: Mar 12, 2018, 11:04 pm by ieee488
You do realize serial.begin(9600); has to be called first, right ?  ? ?
tuila
Yes I had it there before and then moved it in front just to see if it would change anything. Either way it does not work and only shows up when I hit the reset button.
Delta_G
I noticed something similar in a esp8266 project I was working on.  I was able to solve it by placing a bit of delay (250ms IIRC but I didn't experiment) between the Serial.begin and the Serial.print.  That seemed to fix it.  Not sure why.  Maybe the ESP just needs some time to get things started.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
tuila
So do you mean you just used a delay(250); line in the void setup?
Delta_G
|| | ||| | || | ||  ~Woodstock
tuila
Darn that  did not work. Although it did delay the print statement to come out .250 seconds after I hit the reset (after the same gibberish letters).
