Topic: Lcd 128x64 menu (Read 276 times) previous topic - next topic
geosignals
Good morning I'm new to programming with arduino.
I'm trying to build one Menu to lcd 128x64.
I've downloaded an example from (display grafico 128x64 arduino cia) It's good and working.
My problem is to pinch a button that when I click on it for a few seconds to change the screen and stay there until I get it Black.
If you can help me please, the example is below.
GraphicsTest.pde
>>> Before compiling: Please remove comment from the constructor of the
>>> connected graphics display (see below).
Universal 8bit Graphics Library, http://code.google.com/p/u8glib/
Copyright (c) 2012, olikraus@gmail.com
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions
are met:
* Redistributions of source code must retain the above copyright notice,
  this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
  notice, this list of conditions and the following disclaimer in the
  documentation and/or other materials provided with the distribution.
  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
  CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
  INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
  MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
  CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
  NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
  LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
  STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
  ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
  ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include "U8glib.h"
// A linha abaixo define as ligacoes e deve ser
// ajustada conforme o display utilizado.
U8GLIB_ST7920_128X64_1X u8g(6, 5, 4 ,7); //Enable, RW, RS, RESET
int display = 1;
void u8g_prepare()
  u8g.setFont(u8g_font_6x10);
  u8g.setFontRefHeightExtendedText();
  u8g.setDefaultForegroundColor();
  u8g.setFontPosTop();
void u8g_Tela1()  //Tela 1 - Arduino e Cia - Retangulos
  u8g.setFont(u8g_font_unifont);
  u8g.drawStr( 11, 35, "Arduino e Cia");
  u8g.drawStr( 12, 35, "Arduino e Cia");
  u8g.drawFrame(0,0,128,64);
  u8g.drawFrame(2,2,124,60);
void u8g_Tela2() //Tela 2 - Moldura e relógio
  u8g.drawRFrame(0,0,128,64,3);
  u8g.drawStr( 3, 10, "Hor.: 13:00");
  u8g.drawStr( 3, 25, "Temp: 27");
  char s[2] = " ";
  s[0] = 176;
  u8g.drawStr(51, 25, s);
  u8g.drawStr( 3, 40, "Umid: 25%");
  u8g.drawCircle(95,32,28);
  u8g.drawCircle(95,32,29);
  u8g.drawLine(95, 9, 95, 4);
  u8g.drawLine(123, 32, 118, 32);
  u8g.drawLine(95, 55, 95, 60);
  u8g.drawLine(67, 32, 72, 32);
  u8g.drawLine(95, 32, 95, 12);
  u8g.drawLine(95, 32, 100.8, 21.87 );
  u8g.setFont(u8g_font_04b_03);
  u8g.drawStr(89,43, "Tag");
  u8g.drawStr(85,50, "Heuer");
void u8g_Tela3() //Tela 3 - Caracteres Ascii - Pag. 1
  char s[2] = " ";
  u8g.drawStr( 0, 0, "ASCII page 1");
  for(int y = 0; y < 6; y++ )
    for(int x = 0; x < 16; x++ )
      s[0] = y*16 + x + 32;
      u8g.drawStr(x*7, y*10+10, s);
void u8g_Tela4()  //Tela 3 - Caracteres Ascii - Pag. 2
  char s[2] = " ";
  uint8_t x, y;
  u8g.drawStr( 0, 0, "ASCII page 2");
  for( y = 0; y < 6; y++ )
    for( x = 0; x < 16; x++ )
      s[0] = y*16 + x + 160;
void u8g_Tela5() //Tela 5 - Arduino e Cia - Retangulo preenchido
  u8g.drawBox(0,0,128,64);
  u8g.drawBox(2,2,124,60);
  u8g.setColorIndex(0);
void u8g_Tela6()  //Tela 6 - Arduino e Cia em 0, 90 e 270 graus
  u8g.setFont(u8g_font_helvB08);
  u8g.drawStr(50,31, " Arduino");
  u8g.drawStr90(50,31, " e");
  u8g.drawStr270(50,31, " Cia");
void u8g_Tela7() //Tela 7 - Fontes diferentes
  u8g.setFont(u8g_font_robot_de_niro);
  u8g.drawStr(5,13, "Arduino e Cia !");
  u8g.drawStr(5,25, "Arduino e Cia !");
  u8g.drawBox(5,31, 118,11);
  u8g.setFont(u8g_font_8x13);
  u8g.drawStr(5,41, "Arduino e Cia !");
  u8g.setColorIndex(1);
  u8g.setFont(u8g_font_ncenB10);
  u8g.drawStr(5,60, "Arduino e Cia !");
void draw() //Rotina Desenho
  u8g_prepare();
  switch(display) //Carrega a tela correspondente
   case 1:
    u8g_Tela1();
   case 2:
    u8g_Tela2();
   case 3:
    u8g_Tela3();
   case 4:
    u8g_Tela4();
   case 5:
    u8g_Tela5();
   case 6:
    u8g_Tela6();
   case 7:
    u8g_Tela7();
  // flip screen, if required
  //u8g.setRot180();
  // assign default color value
  if ( u8g.getMode() == U8G_MODE_R3G3B2 )
   u8g.setColorIndex(255);   // white
  else if ( u8g.getMode() == U8G_MODE_GRAY2BIT )
   u8g.setColorIndex(1);     // max intensity
  else if ( u8g.getMode() == U8G_MODE_BW )
   u8g.setColorIndex(1);     // pixel on
  //u8g.setContrast(0x30);
  // picture loop
  for (display =1; display < 8; display++) //Carrega as telas de 1 a 7
    u8g.firstPage();
    do
    draw();
    while( u8g.nextPage() );
    delay(3000);  //Pausa de 3 segundos e reinicia o processo
geosignals
GraphicsTest.pde
are met:
#include "U8glib.h"
int display = 1;
void u8g_prepare()
  char s[2] = " ";
  s[0] = 176;
  char s[2] = " ";
  char s[2] = " ";
  uint8_t x, y;
  u8g_prepare();
   case 1:
    u8g_Tela1();
   case 2:
    u8g_Tela2();
   case 3:
    u8g_Tela3();
   case 4:
    u8g_Tela4();
   case 5:
    u8g_Tela5();
   case 6:
    u8g_Tela6();
   case 7:
    u8g_Tela7();
  //u8g.setRot180();
  // picture loop
    u8g.firstPage();
    do
    draw();
I have the slightest changes the problem is that the change of the screen takes place only when I press and hold the button,I want to change the screen by pressing the button and stay on that screen until you get the button again..
#include "U8glib.h"
// Η παρακάτω γραμμή ορίζει τους συνδέσμους και πρέπει να είναι
// ανάλογα με την οθόνη που χρησιμοποιείται
// constants won't change. They're used here to set pin numbers:
const int buttonPin = 2;     // the number of the pushbutton pin
// οι μεταβλητές θα αλλάξουν:
int buttonState = 0;         // μεταβλητή για την ανάγνωση της κατάστασης του κουμπιού
void u8g_prepare()
void u8g_Tela1()  //Οθόνη 1 - διαφημιστικη Οθόνη
  u8g.drawStr( 8, 19, " arduino ");
  u8g.drawStr( 9, 19, " arduino ");
  u8g.drawStr( 0, 35, " cia ");
  u8g.drawStr( 1, 35, " cia ");
  u8g.setFont(u8g_font_tpss);
  u8g.drawStr(7,55, "kdjfhgkdjgf.kdkd");
void u8g_Tela2() //Οθόνη 2 - κεντρική Οθόνη
  u8g.drawFrame(0,0,40,64);
  u8g.drawFrame(41,0,87,64);
  u8g.drawStr(7,10, "menu");
  // άλλη οθόνη, εάν απαιτείται
  //u8g.setRot180();
  // εκχωρήσετε προεπιλεγμένη τιμή χρώματος
   u8g.setColorIndex(255);   // άσπρο
   u8g.setColorIndex(1);     // μέγιστη ένταση
  //   αρχικοποιήστε τον πείρο του κουμπιού ως είσοδο:
  pinMode(buttonPin, INPUT);
void loop(){
    // εικόνα βρόχου
    buttonState = digitalRead(buttonPin);
    u8g.firstPage();
    do {
      if (buttonState == LOW)
        u8g_Tela1();
      if (buttonState == HIGH)
        u8g_Tela2();
    delay(10);  //Παύση για 10 δευτερόλεπτα και επανεκκίνηση της διαδικασίας
