Loading...
Pages: [1]   Go Down
Author Topic: controllin dc motor with lm35 using arduino.  (Read 2001 times)
Offline Offline
Newbie
View Profile
hello,
                  i want to write a program to control dc motor using lm 35.  for first time, if temp reaches 75 the motor should be stopped..then from next loop if temp is less than 55 , motor should be on..pls help me out..i dont know programming in arduino.. smiley-slim
Logged
Sussex UK / CT USA
Offline Offline
Edison Member
Forums forever
View Profile
WWW
Split the problem into it's two parts....
Write a program to turn the motor on and off as you press a button.
Write a program to turn an LED on and off, depending on the temperature seen.
Once those are working, blending them into a single program is relatively easy.
For a course on Arduino programming...
http://sheepdogguides.com/arduino/FA1main.htm
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
For motors you will need some hardware to drive them. See:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
Logged
Pages: [1]   Go Up
Print
Jump to:
