Topic: ArduinoUNO Pin 3 problem! (Read 218 times) previous topic - next topic
steelz75
After several days of testing with Shield Protoneer 3.0 + fw GRBL 1.1f, perfectly working, I decided to test the modified fw 0.9i for Servo on Z axis and the first problems started ... the Y axis stopped working and after several checks on the cables I realized, through a small control sketch on the digital ports, that the digital pin 3 of the Arduino Uno, the one that sends steps pulses to the Y driver, no longer works. AtMega328 burned or recoverable?
steelz75
It is possible a power return in case i have moved the Y plane manually? Probably the digital output 3 is burned out  :(
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
What model Arduino do you have?
Has it got the DIL type controller IC?
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
steelz75
#3
Mar 13, 2018, 11:16 am Last Edit: Mar 13, 2018, 11:23 am by steelz75
This one...
Probably the digital out 3 is burnt. I have already ordered a couple of spare atmega328 that I will reprogram via ISP with the bootloader...
Thanks
