Topic: using A6 or A7 for blink led (Read 465 times) previous topic - next topic
jawadph
hello
i want using A6 pin or 7 the nano for led bacause i dont have ather free pin .if that possible
or for lcd
larryd
A6 and A7 are for analogs only on a Nano.
No technical PMs.
The last thing you did is where you should start looking.
CrossRoads
A6, A7 are analog input only. Can't drive LEDs with them.
jawadph
how add pin or how use lcd withe 74hc959
6v6gt
#4
Mar 14, 2018, 03:32 am Last Edit: Mar 14, 2018, 05:10 am by 6v6gt
Use pins A6 and A7 to free up two pins you are currently using for inputs (buttons etc.).
You'll need an external pullup resistor.
septillion
Only need a pull up is you currently read a button (with pinMode(pin, INPUT_PULLUP)). If you swap an analog reading from A0 - A5 you're all good.
But if you want more useful tips, post a schematic (NOT a Fritzing breadboard view) of your circuit + a description of what it does.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
