Topic: How to use millis function to turn led on for 5s then turn it off indefinitely? (Read 5862 times) previous topic - next topic
pluggy
It would need to be done in the main loop to use millis().
const int ledPin =  13;      // the number of the LED pin
unsigned long time;
 // set the digital pin as output:
 pinMode(ledPin, OUTPUT);
 digitalWrite(ledPin,LOW);
{  time= millis();
  if (time >= 1000 && time < 1020){digitalWrite(ledPin,HIGH);};  // turn it on when its been running for a second
  if (time >= 6000 && time < 6020){digitalWrite(ledPin,LOW);};  // turn it off when its been running for 6 seconds
// write rest of code here . as written it will repeat about every 49 days when millis() 'goes round the clock'
Tested code.......
The 1020 and 6020 figures will need to be tweaked if the loop time exceeds 20 milliseconds.
http://pluggy.is-a-geek.com/index.html
jstone
For some reason im still not getting the result i hoped for...
I entered the millis code you just quoted but still nothing. Am i missing something obvious?
const int buttonPin = 2;     // the number of the pushbutton pin
const int ledOdd =  13;      // the number of the LED pin
const int ledEven = 50;
// variables will change:
int buttonstate = 0;
// variable for reading the pushbutton status
int buttonPress = 0;
int buttonPresses = 0;
int ledState = LOW;
int ledEoff = LOW;
// ledState used to set the LED
long previousMillis = 0;
long interval = 1000;
long intervalTen = 10000;
unsigned long time;
  // initialize the LED pin as an output:
  pinMode(ledOdd, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPin, INPUT);
  pinMode(ledEven, OUTPUT);
void loop(){
    time= millis();
   if (time >= 1000 && time < 1020){digitalWrite(ledEven,HIGH);};  // turn it on when its been running for a second
   if (time >= 6000 && time < 6020){digitalWrite(ledEven,LOW);};  // turn it off when its been running for 6 seconds
  // read the state of the pushbutton value:
  buttonstate = digitalRead(buttonPin);
buttonPresses = buttonPresses;
  if(buttonstate == HIGH) buttonPresses ++;
  boolean odd = buttonPresses % 2;
  if(odd){
//this will only happen if buttonPresses is odd
unsigned long currentMillis = millis();
  if(currentMillis - previousMillis > interval) {
    // save the last time you blinked the LED
    previousMillis = currentMillis;
    // if the LED is off turn it on and vice-versa:
    ledState = !ledState;
    // set the LED with the ledState of the variable:
    digitalWrite(ledOdd, ledState);}
else{
//this will only happen if buttonPresses is even
    digitalWrite(ledEven, ledState);}
    unsigned long  currentMillis2 = millis();
    if(currentMillis2 - previousMillis > intervalTen){
      previousMillis = currentMillis2;
      ledEoff = ledEoff;
      digitalWrite(ledEven, ledEoff);}
Groove
I dont want to use the delay function i want to use the Millis function?
Doesn't "delay()" use "millis()"?
Per Arduino ad Astra
pluggy
jstone
Hmmm still having trouble.
I dont want to use the delay function as it stopps running the other code.
I have moved all the code about and tried this. I have used some of your code again Pluggy.
int ledState = LOW;
unsigned long time;
unsigned long time2;
 if(odd)
   time= millis();
   if (time >= 1000 && time < 1020){digitalWrite(ledOdd,HIGH);};  // turn it on when its been running for a second
   if (time >= 6000 && time < 6020){digitalWrite(ledOdd,LOW);};  // turn it off when its been running for 6 seconds
if(!odd)
time2= millis();
   if (time2 >= 1000 && time2 < 1020){digitalWrite(ledEven,HIGH);};  // turn it on when its been running for a second
   if (time2 >= 11000 && time2 < 6020){digitalWrite(ledEven,LOW);};  // turn it off when its been running for 6 seconds
Can anyone see why its not working??
stoopkid
perhaps he want to continue running code while it waits?
AWOL
Perhaps s/he should have stated that.
(And no, delay doesn't use "millis", it uses "micros")
pluggy
The second proviso in the if statement  is to give a window to turn off the LED. If you knew the loop would catch every millis() you could just use a single '==' statement.  The if will never flag because The first part says that time2 has to be more than 11 seconds and the second part says it has to be less than 6.02 seconds which can't happen.
This should work :
if (time2 >= 11000 && time2 < 11020){digitalWrite(ledEven,LOW);};  // turn it off when its been running for 11 seconds
You're going to need to start understanding what code does, rather than depending on other people to write it for you.
jstone
Sorry, i have a strange way of learning. Its not that im trying to get others to write the code for me its just i can get a better explanation for "how and why"..
I tottaly understand what your saying about the "time2" statement. It makes sence now 11020, got it.
Thanks for the code but i haven't been clear. If you look at my "if(odd)" statement does anything there immediately incorrect? As when im pressing my push button the led will not activate..
  if(odd)
    time= millis();
Grumpy_Mike
If you want the LEDs to stay off then don't reset the timer after turning it off, in other words don't do this
jstone
unsigned long time;
{  time= millis();
When i add a button press to this it no longer works?
What am i missing?
const int ledPin = 50;
int buttonState = 0;
int ledState = LOW;
int ledEoff = LOW;
unsigned long time;
 digitalWrite(ledPin, LOW);
void loop(){
 time= millis();
 if(buttonState == HIGH) {
