Topic: Serial Sniffer (Read 6306 times) previous topic - next topic
baum
So I found two 3V devices that comunicate over some sort of serial. (maybe its one wire) I have the two devices talking to eachother, but I want to hack them with my arduino. Can someone tell/show me how to make a sniffer to listen in on the serial connection? (transfer speed is not a problem, the devices are very slow.)
Thanks!
Grumpy_Mike
Use an arduino oscilloscope.
Alternativly you can use the sort of thing people use for sniffing IR remote controllers.
TonyD
Check out the Dangerous Prototypes Bus Pirate
http://dangerousprototypes.com/bus-pirate-manual/
AlphaZeta
Depending on whether the waveform is periodical, simple oscilloscope might not work because the trigger point will shift and the waveform won't be stable.
If you have a digital scope, you can use the single shot function which will be able to capture arbitrary waveform. Of course, you can always use a dedicated logical analyzer.
dcb
you can also use a sound card to record it to a file and analyze the waveform.
