Topic: bi color led matrix problem (Read 2159 times) previous topic - next topic
patryk
i found this code and i'm trying to modify it to work with 8x8 bi color matrix (http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203747843/15)
so basically i need to control 8 columns x 16 rows. sounds simple but.....
i've managed to get all 3 colors working but only on half of my matrix (so still 8x8)
could someone take a look at this code and tell me where i made a mistake? ;)
(i'm using arduino mega and directly connected matrix http://www.artronic.pl/o_produkcie.php?id=757?)
Code: [Select]
* Show messages on an 8x8 led matrix (cathode rows) //in my case anode,
* scrolling from right to left.
* Pinouts & code by Andrew
* see http://arduino.pastebin.com/f35fdf323
* see http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1203747843/13#13
// pin[xx] on led matrix connected to nn on Arduino (-1 is dummy to make array start at pos 1)
int pins[25]= {-1, 22, 24, 26, 28, 30, 32, 34, 36, 38, 40, 42, 44, 45, 43, 41, 39, 37, 35, 33, 31, 29, 27, 25, 23};
// (for some reason I ended up with different pinouts that Andrew's)
// col[xx] of leds = pin yy on led matrix
int rows[16] = {pins[11], pins[10], pins[8], pins[7], pins[5], pins[4], pins[2], pins[1], pins[14], pins[15], pins[17], pins[18], pins[20], pins[21], pins[23], pins[24]};
// row[xx] of leds = pin yy on led matrix
int cols[8] = {pins[22], pins[19], pins[16], pins[13], pins[3], pins[6], pins[9], pins[12]};
// Letter definitions based on 5 bit-wise columns (5 x 7 font)
#define M1 {65535, 65535, 65535, 65535, 65535}
#define M2 {21845, 21845, 21845, 21845, 21845}
#define M3 {43690, 43690, 43690, 43690, 43690}
#define AAA {21, 68, 324, 68, 21}
int dispSpeed = 10; // Constrols scroll speed (1 minimum, way too fast)
byte bit[16] = {32768, 16384, 8192, 4096, 2048, 1024, 512, 256, 128, 64, 32, 16, 8, 4, 2, 1}; // Used for bit comparisons
byte colVals[8] = {0, 0, 0, 0, 0, 0, 0, 0}; // Hold display columns (initaly blank)
// Define display string here
const int charNum = 6;     // Number of letters in display string
byte string[charNum][5] = {M1,AAA,M2,AAA,M3,AAA};
  for (int i = 1; i <= 24; i++) {   // sets the pins as output
    pinMode(pins[i], OUTPUT);
  for (int col = 0; col < 8; col++) {    // set up cols and rows
    digitalWrite(cols[col], LOW);
  for (int row = 1; row < 16; row++) {
    digitalWrite(rows[row], LOW);
  for (int ltr = 0; ltr < charNum; ltr++){// For each letter in string array
    for (int y = 0; y < 6; y++){     // For each columin in letter + one space
shiftLeft(); // shifts display columns left
if (y < 5){
  colVals[7] = string[ltr][y]; }    // add new letter column on right
else {colVals[7] = 0; } // or empty space between
for (int x = 0; x < dispSpeed; x++){// loop to refresh display x times ton control scrolling
  display();
void shiftLeft(){
for (int x = 0; x < 7; x++){
   colVals[x] = colVals[x + 1];
void display() {
   for (int col = 0; col < 8; col++){
    for (int row = 0; row < 16; row++){
if (colVals[col] & bit[row]){
  digitalWrite(rows[row], LOW);}
    digitalWrite(cols[col], HIGH);  // Turn on column
    delay(1);  // Delay for POV
digitalWrite(rows[row], HIGH);
    digitalWrite(cols[col], LOW);  // And off
MarkT
You're using a byte array to hold 16 bit values but byte is defined as unsigned 8 bit value.  Change it to int or unsigned int.
I'm not sure why you want to store powers of two, they are easy/fast enough to generate on the fly with the shift operator:
Code: [Select]
int bit = 1 << row ;
