Loading...
Pages: [1] 2   Go Down
Author Topic: Arduino Mini 04 with ATmega328  (Read 6145 times)
Offline Offline
Newbie
View Profile
I just received an Arduino mini 04 with an ATmega328 (instead of an ATmega168) from Sparkfun and I am having issues uploading sketches to the board.  I have selected Arduino Mini as my board and have selected the correct COM Port.  I have wired the mini USB extension adapter and board according the guide here: http://arduino.cc/en/Guide/ArduinoMini  I am getting power to the arduino mini 04 board no problem.
I tried to upload the Blink example sketch it continues to say "Uploading to I/O Board..."  and never finishes uploading even after 20 minutes.  I am running the latest Arudino 0022 onn a windows 7 machine.  Anyone have any idea why it stalls during the upload?
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Hold down the Shift key when you click the Upload button.  What shows up in the output / status window?
Logged
Offline Offline
Newbie
View Profile
C:\Users\me\Documents\Arduino\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Users\me\Documents\Arduino\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P\\.\COM6 -b19200 -D -Uflash:w:C:\Users\me\AppData\Local\Temp\build5884620712314103115.tmp\Blink.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "C:\Users\me\Documents\Arduino\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM6
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 19200
avrdude: ser_open(): setting dtr
And thats is nothing else it still says uploading to I/0 Board.  Does it think the mini is has a ATmega 168? would that cause an issue because the mini 04 I have has an ATmega328
Logged
Global Moderator
Dallas
Offline Offline
Shannon Member
View Profile
WWW
Quote
That isn't the problem.  AVRDUDE isn't reaching the microcontroller.  You could have a Motorola 68000 processor on the other end and the symptom would be the same.
Quote
Looks like AVRDUDE is getting stuck in the kernel driver.  I can think of two things to try...
1. Ensure you are using the latest drivers for the "mini USB extension adapter"
2. Different USB cable
Logged
Offline Offline
Newbie
View Profile
WWW
Hello,
I seem to have the same issue.  I also purchased a Mini from Sparkfun and the chip is a 328.  I have tried every trick I could find on these forums and nothing seems to work.
I have circuit with a reset button...I tried to time the reset...
I have an interface with the DTR line of the Mini USB adapter (newest version).  ( I copied off the the Nano schematic)  This does work because the indication LED blinks 3 times when I hit upload in the IDE.
No dice...
My circuit:
When I try to upload a sketch I always get the same output as everyone else with Mini upload problems:
"Binary sketch size: 2180 bytes (of a 14336 byte maximum)
C:\Program Files (x86)\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega168 -cstk500v1 -P\\.\COM4 -b19200 -D -Uflash:w:C:\Users\saec-kv\AppData\Local\Temp\build6545575129176962314.tmp\AnalogInput.cpp.hex:i
         System wide configuration file is "C:\Program Files (x86)\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM4
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x20
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xcc
avrdude done.  Thank you."
Also, after the board is reset, it does the 3 quick LED flashes to state that the bootloader is running.  After a couple more seconds the LED will flash one time, with a longer on duration, and then is sends via serial the following error message:
"ERROR:pin 2-3"  I cannot find any documentation of where this error message comes from.  I have combed the source code for the bootloaders, avrdude, and anything else I can find.  Nothing...
Lastly,
I tried to re-burn the bootloader as a normal Mini (168) and I get this error message:
avrdude: Expected signature for ATMEGA168 is 1E 94 06
         Double check chip, or use -F to override this check.
Sorry for the long post.
Any Ideas?
~Matt
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
The Mini 04 needs the reset button pressed when you upload in my experience.  If it has a 328 then try the Pro Mini 328 5V setting for the board.  Or the duemilanova - so long as the processor and clock speed match it ought to work.
Logged
Netherlands, Arnhem
Offline Offline
Newbie
View Profile
Has anyone worked this one out yet?
I seem to have the same problem: arduino mini4 with AtMega 28p
I use the setup as described in: http://arduino.cc/en/Guide/ArduinoMini with the usb adapter also (old version_ so different from the example_ could this affect something?)
and after resetting, the led connected to pin13 flashes 3 times, and when i press upload (also tried different timing etc.) it says:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0xc)
also tried different serial ports and different boards / combinations  in the tools menu but nothing seems to work
Logged
Offline Offline
Newbie
View Profile
Same problem
however i did notice the arduino is constantly sending 4 byte messages
captured over 5 seconds:
F5   B2   52   FA      F5   86   52   FA      F5   86   52   FA      F5   86   22   FA      F5   B6   52   FA      F5   86   52   FC      F5   86   52   FA      F5   86   52   FA      F5   86   52   FA      F5   86   52   FA      49   86   52   FA      F5   86   52   FA      F5   B1   52   FA      F5   86   22   FA      F5   86   22   FA      F5   86   52   FA      F5   A6   52   FA      F5   86   52   FA      F5   B1   52   FA   F5   86   52   FA
Logged
Offline Offline
Newbie
View Profile
anyone got a solution yet ?
Logged
Versailles France
Offline Offline
Newbie
View Profile
sparkfun mini usb  + Sparkfun arduino mini ( with AT328 and unknowed bootloader ) : same issue, same results...
I have looked carefully on arduino pro 5V to apply the same schematic ( reset , supply , DTR connection ) on these arduino mini .
I use arduino software with arduino pro 5V  16 Mhz setting : upload start..and nothing append.
Next step : upload bootloader from arduino software, and try again. I'm waiting my tinyusb board.I have choosed these Sparkfun solution to have efficienty hardware solution : it is not : A lot of time loosed...
Logged
Offline Offline
Newbie
View Profile
I finally got it to work:
So I returned the Arduino 04 mini and received arduino mini pro and had the same problem.  Then I thought it was the usb adapter so I ordered a the FTDI Basic Breakout - 5V.  Same problem same errors.
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Then I tried a different computer running windows XP and it worked!  It still does not work on the 64 bit windows 7 for some reason.  Both machines were using Arduino 0022.  I could also be a driver issue, but I did try updating the drivers for the USB breakout board at some point and it didn't help.
Logged
Offline Offline
Newbie
View Profile
Weird. I tried win xp but wihtin a vmware. I'll reinstall win xp on my test rig and give it a try
Logged
Offline Offline
Newbie
View Profile
Hi everybody
Same problem here. Tried it on Mac OS X 10.6.7 and Windows XP (fresh installation).
Using:
-Arduino Mini 04 with ATmega328
-Arduino Serial USB Board (connected like showed in the guide)
-Arduino SW 0022
Logged
Offline Offline
Jr. Member
View Profile
WWW
Same here. Any solutions?
Logged
Offline Offline
Newbie
View Profile
Problem solved!
Add the following lines to boards.txt:
Code:
mini328.name=Arduino Mini with ATmega328
mini328.upload.protocol=stk500
mini328.upload.maximum_size=28672
mini328.upload.speed=115200
mini328.bootloader.low_fuses=0xff
mini328.bootloader.high_fuses=0xd8
mini328.bootloader.extended_fuses=0x05
mini328.bootloader.path=bt
mini328.bootloader.file=ATmegaBOOT_168_atmega328.hex
mini328.bootloader.unlock_bits=0x3F
mini328.bootloader.lock_bits=0x0F
mini328.build.mcu=atmega328p
mini328.build.f_cpu=16000000L
mini328.build.core=arduino
Now you can select your board "Arduino Mini with ATmega328". Do a reset 1 second before upload.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
