Pages: 1 [2]   Go Down
Author Topic: Arduino Mini 04 with ATmega328  (Read 5929 times)
Versailles France
Hello.
After a lot of spending time, I confirm that it works also for me !!
Thank's a lot FRY!!!! Newbie ..but efficient !!!!
how did you understand the solution of these issue??
Same here, works like a charm. you rock dude smiley-wink
FANTASTIC smiley smiley-mr-green smiley-grin
Adding the new board type worked for me.
Thanks for you help.
~Matt
I can't believe they did not publish this change on the site or better update the IDE's files. Only clue was a tiny sticker saying "328" on the mini. But that actually covered the processor so it took me some time to figure out that actually represented the processor type! This cost me half a day of development time...
But thank's a million for the solution or I would still be breaking my head over this.
Hello,
I have the same problem and try use the solution posted, but now i get this;
Binary sketch size: 970 bytes (of a 28672 byte maximum)
C:\Users\Daniel Melo\Documents\Projectos\arduino-0022\hardware/tools/avr/bin/avrdude -CC:\Users\Daniel Melo\Documents\Projectos\arduino-0022\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM13 -b115200 -D -Uflash:w:C:\Users\DANIEL~1\AppData\Local\Temp\build3196484183096855382.tmp\BlinkWithoutDelay.cpp.hex:i
avrdude: Version 5.4-arduino, compiled on Oct 11 2007 at 19:12:32
         System wide configuration file is "C:\Users\Daniel Melo\Documents\Projectos\arduino-0022\hardware/tools/avr/etc/avrdude.conf"
         Using Port            : \\.\COM13
         Using Programmer      : stk500v1
         Overriding Baud Rate  : 115200
avrdude: ser_open(): setting dtr
avrdude: Send: 0 [30]   [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x1c
avrdude: Send: Q [51]   [20]
avrdude: Recv:
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x1c
avrdude done.  Thank you.
I´m using a USB 2 Serial Light to upload the Sketch.
Please help.
Thanks
I have the exact same error that daniel_melo is getting.  I updated boards.txt with the new profile.  No luck. FTDI and Arduino IDE are up to date, have power, etc.
This is such bull.  On the bright side I think this might be the Arduino FAIL that pushes me over the edge.  Time to learn to use PICs instead of wasting time and money on a company that doesn't give a shit.
We were born naked, wet and hungry. And then things get worse!!!
I am using the same Arduino Mini 04 with Arduino 1.0 IDE . Insted of using a Mini USB adapter, I am using Arduino Duemilanove. The wiring is as follows
http://arduino.cc/en/Guide/ArduinoMini
I get supply to the board, but When I try to upload, I get
Binary sketch size: 1026 bytes (of a 28672 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
I even tried pressing shift while uploading, I get the same error
Also, As suggested, I copied
Mini with ATmega328
mini328.upload.protocol=stk500
mini328.upload.maximum_size=28672
mini328.upload.speed=115200
mini328.bootloader.low_fuses=0xff
mini328.bootloader.high_fuses=0xd8
mini328.bootloader.extended_fuses=0x05
mini328.bootloader.path=bt
mini328.bootloader.file=ATmegaBOOT_168_atmega328.hex
mini328.bootloader.unlock_bits=0x3F
mini328.bootloader.lock_bits=0x0F
mini328.build.mcu=atmega328p
mini328.build.f_cpu=16000000L
mini328.build.core=arduino
to the boards txt. (Thoguh it already had 1)
I still get the same problem. I also tried changing ports and USB cable.
Please suggest
Thankyou
Regards
México
Buen dia!!!
Gooooooooooooooood, My Arduino Mini 04 it's working.
-Windows 7 64 bits
-Arduino 0022
-Sparkfun Items: DEV-08164 and DEV-08165
with the modify in the file boards.txt:
mini328.name=Arduino Mini with ATmega328
Ing. Surinam Zambrano S.
Ingeniero en Sistemas
Tel Móvil: +52-656-310-1572
Diseño de Sistemas Ingenieriles, S. de R.L. Mi. (DSI / Electroniz)
C. Trigo #8105
Col. El Granjero. C.P. 32690
Cd. Juárez, Chih. MX.
Tel:+52-656-620-5120 y 21
http://www.electroniz.com
Design Of Engineering Systems (CELEMEX)
306 E. Paisano Suite 607
Zip Code: 79901
El Paso, Texas. USA.
Ph: +1-915-317-3918
Same situation, same problem. I get this error:
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Pages: 1 [2]   Go Up
