Pages: [1] 2 3 4   Go Down
Author Topic: Ultrasonic Anemometer  (Read 11502 times)
Australia
AVR Microcontrollers
This picture shows the anemometer in position:
This picture shows a 4 day logged output using my VB program:
I have previously posted this project at:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1283073954
I have made some more improvements to the design.
I am now happy with the long term operation of this anemometer.
Full details including project description, modification descriptions,
circuit diagrams and all the programs:
Download UltrasonicAnemometer.zip from:
http://code.google.com/p/mysudoku/downloads/list
When I took on this project I searched the web and could not find any
real information on how the software should work.
In the end I went for time of flight for coarse values and phase shift for the finer detail.
I believe that this is the only ultrasonic anemometer on the web which has
enough detail to enable it’s actual construction.
New River, Arizona
Very nice.  After running it for a few months it must be really satisfying to have the project working day after day.  Maximum bragging rights.
Good job
Trying to keep my house under control http://www.desert-home.com/
Australia
Thanks draythomp.
I am bragging, I put so many hours into this project that I feel I have a right to a little bragging.
I would rather had put much fewer hours in, but I was unable to find any real information on the web.
I'm hoping to get a little bite about:
Maybe from the many authors of web sites which claim to describe  ultrasonic anemometers.
Australia
I have just noticed that if you do a google search:
ultrasonic anemometer construction
This page comes up on the first page of the google search.
I dont know how long this has been occuring but it also has the quote:
I'm still waiting to be proved wrong.
I would not be upset if proved wrong, but it would mean that I would have to improve my search technique.
Carl (i guess this is your name),
Great project and taking the time to share with the comunity . I have a few question that would help me to understand your design
1) Where do you get the formula  v = SQRT((d/t)*(d/t)+(C*C)) - d/t  ?
1)Why the 300 samples ? I see you explain and show math about the 3 seconds and get 312 samples to produce 1 measure.
You can use just 100 samples or even less and still get good results .
2) Why are you mention to get TOF in multiples of 25 usecs (instead of real time)? You send the pulses (actually 16 )and should be able to get the time to arrive. You could send the pulses , start timer and stop when it arrives .
3) I am not sure to understand why you use the 74HC368 drivers? Could you use just the I/O pins of the microcontroller directly?
4) What do you use zero detector and envelope for ?
Regards,
Zenon
Australia
We can find the wind velocity from the equation:
Vns = d/2 *( 1/tns - 1/tsn)
We can solve this(algebra) for the magnitude of the wind velocity when we have the time difference:
V = SQRT((d/t)*(d/t) + C*C) - d/t
Where t = largest tof - smallest tof.
The wind gust peak is usually averaged over 3 seconds(historical from the time constant of cup
anemometers).
This gives a sample size of 300.
Any smaller size can be used but you will get more noise in your result.
This is the crux of the problem. To get precision of 0.1 usecs is impossible with TOF.
My solution is to use the coarse TOF to get the TOF to within a 25 usec range.
I then use the phase shift to get the precise TOF within that 25 range.
You can drive the transducers direct as I did in my first prototype.
I have given the code:
//PORTD is at 0x0b pin 6 controls NORTH HIGH pin 7 controls NORTH LOW
asm volatile ("\n\t"
"ldi r25 , 16 \n\t" //set pulse counter to 16
"pulse1%=:" "\n\t" //branch back here till 16 pulses sent
"sbi %0 , 6 \n\t" //turn on NORTH HIGH
"cbi %0 , 7 \n\t" //turn off NORTH LOW
ect
This does not give a fine enough control of the pulse frequency.
Timer0(Arduino millis() and PWM 5 & 6) is used as an exact frequency source for the ultrasonic.
To get the differential feed requires that I had to use 2 74HC368 drivers,
but it is not to extravagant to get the best S/N ratio.
The envelope detector is used to get the coarse TOF.
The zero crossing is used to get the phaseshift(fine detail) of the waveform.
« Last Edit: April 18, 2011, 01:30:39 am by carl47 » Logged
1) What do you mean by "largest" /"smallest" TOF . So this formula is based on "large" number of samples and I pick largest and smallest and substracts them to get "t" ?
2) i still do not understand the big picture of you method to determine the wind speed
I see your explanation as follow  :
1) You send pulses for .64 msec
2) After that wait .48 msec for settle down
3) Here is my problem...you say active waiting 1.28 ms for INT0 and INT1 .
I do not understand what happens first, measure phase or detect envelope. Should be envelope, since it is coarse.
So after sending the pulses, just wait for envelope to be detected (capture that value in envelopetof).Once detected, wait for the next crossing zero, capture timer1 again (in zcdtof) . Repeat this 300 times?
In your code i see you use TCNT1 for both zcdtof and envelopetof, so even i read your code, I am sorry do not understand how this works.....
Australia
This equation gives the wind speed when we have the TOF( say north to south) and the TOF in opposite direction(south to north).
In the example in the pdf for 1 kph wind we get:
tof from N to S tns = 0.36/(344.7 + 0.277) = 1043.5 micro sec.
tof from S to N tsn = 0.36/(344.7 - 0.277) = 1045.2 micro sec.
So t = 1.7 usec. d = 0.36.  C = 344.7.
subsitute into the equation and get v = 0.277 m/s (1 kph)
If you could measure the TOF using envelope detection (ping distance uses this) with an error of 0.1 usec there would be
no problem.
But the best we can get even with an average of 300 samples is 5 usec(wind noise is the problem).
To get closer I incorporate phaseshift wich can give errors of 0.1 usec with 300 samples.
Good, up to here you have got what I am doing.
The ZCD sets INT0 first.
The counter value is recorded for the use as the phaseshift.
TCNT1 keeps counting
I set the detector levels  so that the ZCD occurs first.
The envelope detector will then set INT1.
The counter value is recorded as the coarse TOF.
TCTN1 is then reset.
« Last Edit: April 19, 2011, 08:07:54 pm by carl47 » Logged
hello guys,
we have trouble with ultrasonic anemometer using pic , we need circuit of this anemometer and which sensor we should use.
in this project, it done with using atmega but we must use pic
could you help us immediately smiley-sad
Carl,
After a year I am back with your project .... I plan to use it in a sail boat and my main concern is what would happen with the boat movement. For sure will introduce errors....well...we will see.
Some additional questions reviewing your excellent document
On the HW side,
1)  why the ZCD  has a pot R 22 ? What is that for? Actually I was surprised to realize that the calibration is done through an external program. What calibration do we need? I mean, as soon as the signal goes above 0V, should rise the output
2) D1 , on the envelope detector, should not be a precision rectifier? I mean, it will bring 0,6 V down
3) On the 4052, why we need -5 V?
On the SW side,
I did, as usual some changes . Basically, I am not using interrupts, but a continuous pulling of ZCD and
envelope.
First a minor comment, regarding the time difference , diff = NZCD[counter]-SZCD[counter] i think is not accurate, because we are sending first 300 samples and then reverse for another 300 . I would expect to send 1 sample (n>s), reverse(s>n), send another sample, reverse and so on , until 300 times.
What I mean if we send pulse 1 , the corresponding reversed pulsed will be after 300 other pulses , so wind changed in that time (well....might not in millisecs....)
Until step 3, I am ok , but struggling to understand your logic in the error correction
It looks like if the diff is less than 200 (ie half period), then you add a pulse. How do you know this?
Then you mentioned the other problem about transducers behavior and define Northerror[20] .
Why 20 values? An again the logic , even is there, not sure to follow why.
Finally, a basic question on tof
Even you mentioned that we do not have individual Tof, I think we do have it, since envelope measures that
This requires that we have each tof as a discrete number.
This we do not have. We cannot use this equation.
What we have is a time difference of multiples of 25 micro sec.""
We send pulses, start TMR1 and capture the value (TMR1 again)when envelope detects it . We substrac and get Tof.
What is true and you mentioned, is that with envelope is not enough to get precision and we need ZCD to find out phase shift .
Regards,
Zenon
Australia
On a rocking sail boat it should be as accurate as an eggcup type. I have used the same response time constant.
We want to detect above the noise level and I want it to occur before the envelope detector. An improvement would be for the ZCD to be fixed and the envelope to be adjustable.
D1 , on the envelope detector.
This is not a rectifier but an Amplitude modulation detector. A precision rectifier would bring the detection level down but I dont know if it is really necessary.
This may be a bit of overkill as the negative voltage on the analog input is very small(it can cope with -5v).
You should try to leave it out and see if it works for you.
Yes but remember we are getting an average over time.
Also I found that you need a couple of pulses before the circuit becomes stable(I drop the first couple of measurements).
I need some more information to answer that.
Now this was just trial and error and I chose 20 as a reasonable figure. This is an area were there could be much improvement.
Yes we do not have an accurate figure for tof to use in that equation.
Keep me informed on your progress.
I am going to revisit this design  as my next project but I will be busy on another project for some months.
Cheers.
Carl,
I was expecting the ZCD to detect zero volts crossing, but you are right, noise might impose a threshold above 0 V.
I also thought that ZCD will allways happen before envelope .
On step # 3 , you are mentioning that the meaasurement might not be in the appropiate pulse, so you get the diff and if it is less than 200 (half pulse), then you add another pulse (400) . if diff is more than half pulse (200), then you remove one.
My question to you is how do you know that this is needed? and what nakes you think that if diff>200 then substract one pulse.
Regards,
zenon
PS : Will let you know my progress . So far , just on the analog side . I have two oamp LM358 for first stage (instead of your transistors), then a precision recitifer (because the diode 1N4148 was not working) , ZCD and envelope detector .
One of my problems is that the tranducer cables, pick the signal from the sending end.So, when I receive the signal, I have a strong one (picked by the cable) and the real signal , very weak.
Australia
What we get is the difference  "diffav" now this value will vary as shown by the wind function.
Using this function we can determine what is needed for a given value.
I used twin shielded microphone cable to feed the transducers. Earth the shield only at the circuit board.
I hope the opamps work.  It will simplify the circuit layout.
hello;
1-i construct the circuit correctly but when i download program to my arduino(arduino uno) it gave me unreal and constant values.I just download operation part and i dont have lcd so i wanna use pc for monitor how can i do this is it possible?
2-Another problem is with transducers(tr-40-16b)  my transducer has two pin one is short and another one is long how can i connect transducer to circuit?we have to use just microphone cable? so how can i connect these transducer with microphone cable?
Thanks...
Australia
I can't follow this. What exactly gives you these values? Is it the Arduino IDE ?
Please provide exact details on what you have connected.
The drive signal is a balanced pair one wire for each pin(long or short). You should use shielded cable which
has a third connection - the shield.
Earth the shield at the circuit board end and leave the end at the transducer unconnected.
« Last Edit: June 02, 2012, 11:53:48 pm by carl47 » Logged
Pages: [1] 2 3 4   Go Up
