Loading...
Pages: [1]   Go Down
Author Topic: Good relays for larger LEDs.  (Read 400 times)
Bergen, Norway
Offline Offline
Newbie
Just4fun
View Profile
Im going to run 2-4 3W IR leds on 8,4V on an arduino. Want the relays to be as small as possible to save space. Any good sugestions?
Was thinking about this one.
http://cgi.ebay.com/Arduino-4-Route-MOSFET-Button-IRF540-/280525487095?pt=LH_DefaultDomain_0&hash=item41509f3bf7
Karl
Logged
SG
Online Online
Sr. Member
Arduino rocks
View Profile
The MOSFET need to operate higher then 9V.
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Good choice, it's compact, powerful and optocoupled!
Your arduino board will be on the safe side of the road, if anything goes wrong with LEDs.
Transfer characteristic chart shows, that it become conductive starting from 5V,
and it's good with 8.4V if current less than 20A, that is more than enough in your case.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Couple of questions:  8.4V seems high for an IR LED - are they running in series?  Is there a reason you need a relay?  I single MOSFET or Darlington would do the job otherwise.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Karl
Well you state wanting to use relays but linked to a 4 channel solid state mosfet switching board, which do you really want to use, either will. That appears to be a nice board you linked to, but the only caution, it is not using logic level mosfets, so it's relying on the applied battery voltage to be high enough to fully turn on the mosfets, they suggest 9vdc as a minimum. However your 8.4 volt voltage source is probably close enough to work OK at the current levels of your led arrays.
Lefty
Logged
Bergen, Norway
Offline Offline
Newbie
Just4fun
View Profile
Im running 3 single watts in series. total of 4,5v and 700mA. The leds have a driver and a voltage step down to suit 8,4 Volt batts. Im running them on 7,4V lipos. (7,4-10,4 actually)  But its no trouble getting smaller or larger lipo batt if needed.
Im not shure whats suits my application. But the link posted seemed to be right for my needs.
Karl
« Last Edit: February 26, 2011, 02:01:51 pm by Wracul » Logged
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
I have that 4- Power FET brick here also, and for less (DISCLAIMER: My Shop):
 =FET&s[title]=Y&s[short_desc]=Y&s[full_desc]=Y&s[sku]=Y&s[match]=all&s[cid]=0]http://arduino-direct.com/sunshop/index.php?l=search_list&s[search]=FET&s[title]=Y&s[short_desc]=Y&s[full_desc]=Y&s[sku]=Y&s[match]=all&s[cid]=0
I have asked the developer of this unit for the schematic and hope to post it soon...
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
Pages: [1]   Go Up
Print
Jump to:
