0
Offline
Edison Member
Wo ein Wille ist, da ist auch ein Weg !
« on: February 26, 2011, 09:03:52 am » |
Are there arduino bootloaders for atmega164, atmega324, atmega644 and atmega1284 ?
I know there is a sanguino bootloader for the atmega644 !
Logged
0
Offline
Newbie
Arduino rocks
« Reply #2 on: April 22, 2011, 07:48:40 am » |
Hello, I have sucessfully flashed an atmega 328 with the bootloader. Now I have an other problm. I would like to use a 644-20PU (44 pin). I read about sanguino and the 644 and 644p bootloader. Can somebody tell me if the bootlader for these 40 pin controllers will work with the 44 pin controller. I know, they have different pinout. Thanks a lot! Robert
Logged
0
Offline
Edison Member
« Reply #3 on: April 22, 2011, 08:30:18 am » |
I have a Atmega644P-20PU it has 40 pins, the Atmega644PA-20PU has 40 pins too !
« Last Edit: April 22, 2011, 08:32:23 am by Megaionstorm »
Logged
0
Offline
Newbie
Arduino rocks
« Reply #4 on: April 22, 2011, 09:26:18 am » |
Hello,
I am sorry, I just saw it is a 644-20AU! Is there a bootloader available or can I use the one vor the 40 pin version?
Thanks Robert
Logged
0
Offline
Edison Member
« Reply #5 on: April 22, 2011, 10:25:54 am » |
I don't know.
But you can try it. Try to transfer the bootloader to your Atmega644, then the blinkwithoutdelay Sketch !
Logged
0
Offline
Newbie
Arduino rocks
« Reply #6 on: April 22, 2011, 11:07:08 am » |
ok, I will try it and reply as soon as I know how it does! thanks and a good evening! Robert
Logged
0
Offline
Edison Member
« Reply #7 on: April 22, 2011, 11:22:16 am » |
You can then connect a led, with a resistor, to each digital out pin.
Then you can check them with a sketch !
This show you if it react like the other atmega644 !
One led after the other !
Logged
0
Offline
Newbie
Arduino rocks
« Reply #8 on: April 22, 2011, 12:34:57 pm » |
good idea, I will make it this way. Robert
Logged
0
Offline
Newbie
Arduino rocks
« Reply #9 on: April 24, 2011, 04:19:42 am » |
Hello, I've been trying for hours to get the 644-20AU running with the sanguino bootloader. I used a Duemilanove board and this method: http://www.geocities.co.jp/arduino_diecimila/bootloader/index_en.htmlI had no problems flashing Atmega 328 on the Duemilanove but encountered problems with the 644: First I connected the 4 control pins of the FT232RL with ICSP Pins of the 644 as well as 5V supply. Reading and setting fuses worked fine. I set low bit FF high bit DC and extended bit FD Erasing and reading flash also worked without trouble. After writing the ATmegaBOOT_644 and ATmegaBOOT_644P I got an rc -1 error although avrdude wrote the code and an error message of different files after verifying. I read it again and the hex file was not empty. After that I conected RX/TX and 5V from the duemilanove to the 644 and tried to flash a sketch via the FTDI chip of the board but It did not work (avrdude: stk500_getsync(): not in sync: resp=0x00 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51) Sanguino software was of course installed and sanguino selected. Can anyone give me a hint ? Thanks Robert
Logged
0
Offline
Edison Member
« Reply #10 on: April 24, 2011, 05:14:37 am » |
I had in the past a equal problem: http://arduino.cc/forum/index.php/topic,22205.msg166852.html#msg166852avrdude: stk500_getsync(): not in sync: resp=0x00 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
Logged
0
Offline
Edison Member
« Reply #11 on: April 24, 2011, 05:25:26 am » |
When burning the bootloader then it's miso and mosi who are used for the transfer.
The sketch are transfered with rx and tx.
Try it with different speed settings in the serial monitor ! From the lowest to the fastest !
Logged
0
Offline
Newbie
Arduino rocks
« Reply #12 on: April 24, 2011, 05:48:19 am » |
I tried to transfer a sketch via Rx/Tx but no way.
Is there an influence on the speed rate of the sketch-transmission when changing the serial monitor settings?
Logged
0
Offline
Edison Member
« Reply #13 on: April 24, 2011, 05:56:43 am » |
This message had give me the idea that the arduino ide and the atmega644 talks in different speed.
not in sync = not in syncronisation
Logged
0
Offline
Newbie
Arduino rocks
« Reply #14 on: April 24, 2011, 06:18:13 am » |
ok, but what can I do then? I assume, that changing baud rate in serial monitor does not affect baud rate during sketch upload.
I have ordered a USB to TTL cable, as suggested for sanguino, yesterday. Do you know, if there are differences between this cable and the FTDI chip on a duemilanove?
Logged
