Topic: Arduino Bootloaders for Atmega164, Atmega324, Atmega644 and Atmega1284 ? (Read 16506 times) previous topic - next topic
Megaionstorm
Read this:
http://sanguino.cc/breadboardsanguino
under serial !
Mein Arduino Projekte Blog:
http://ardu-megatank.blogspot.de/
Megaionstorm
You can use a arduino without a atmega on it to transfer the sketch to the atmega644.
You must connect rx from the arduino board with the tx from the atmega644.
The tx from arduino to atmega644 rx.
Then select sanguino W/atmega644p under boards before you try to transfer the sketch !
rokatz123
oh, good, thanks for that!
I'm going to try this out this evening and reply with the results tomorrow!
Robert
rokatz123
So, I tried to flash a sketch via arduino board without atmega and a TXRX connection to the powered 644.
Still no chance to transfer, 'not in sync'.
I fear, the bootlaoder for the 644 and 644p does not work with a 20AU chip.
Has anybody further ideas?
Robert
WanaGo
Megaionstorm
As i have tried it in the past i had used a 16Mhz crystal with the Amtega644.
rokatz123
Hello,
I also use a 16 MHZ crystal, same as I successfully use with a Atmega 328.
I could flash the sanguino bootloaders 644 and 644p without errors before. Flashing a sketch still doesn't work. To make sure that flashing via RXTX works, I flashed a 328 on a breadboard with 5V, Reset, RX, TX and ground connected. The 644 on a seperate pcb was connected exactly the same with 16MHZ crystal. I checked the pcb certain times and found no mistakes. As I said before, flashing bootloaders works properly.
I'll purchase a 644 20 PU tomorrow, to check weather bootloader and sketches run on it. This will let me know if the bootloader is not suitable for a 44 pin 20 AU.
If anybody had further idas, i'd apreciate.
Robert
Megaionstorm
Could it be the Atmega644 must be resetet short before the sketch transmission ?
rokatz123
may be. Can this be done manually by pressing reset button with reset pins of arduino and 644 connected together?
Megaionstorm
rokatz123
cheers, eventually it works! Simply pressing reset starts sketch transmission! Thank you so much!
A first test with serial interface worked at 115kBaud. The next tests concentrate on finding all IO-Ports.
Robert
rokatz123
Hello again,
I have tried to flash the bootloader on a second 644 after the first worked properly. I used this method: http://www.geocities.co.jp/arduino_diecimila/bootloader/index_en.html
This worked well with the first 644 but not with a new raw one. The chip is soldered on a board like "breadboardsanguino" with a 16MHZ crystal. Reading the fuses of the new chip was no problem in slow mode (-B 4800). In fast mode I go an RC-1 error. Erasing worked fine as well. After setting the fuses to highfuse=DC, lowfuse=FF and extendedfuse=FD, I was no longer able to read the fuses again (error RC-1). A new crystal could not solve the problem.
My questions are:
* why is fast mode not working anymore although it worked with the first 644?
* Is the cable length from the Arduino board to the pcb crucial? (is about 25cm long)
* why can I not get trough after setting fuses for sanguino?
thx!
Robert
skyjumper
Hello again,
My questions are:
thx!
Robert
I just noticed this thread. I am having very similar issues. I read in the docs for the AVR Studio and somewhere else that with a brand new chip, you have the the speed very slowly, I think to 112 KHz.
A 25cm cable should be fine.
As for the fuses, I don't know.
rokatz123
yes, a brand new chip has to be adressed slowly. after erasing, transfer rate can be increased.
i'm confused, because it already worked with the same setup.
