Topic: How to control AC with DC using mosfets (Read 823 times) previous topic - next topic
Deous
Is it easy? What transistor(s) would I need and what to consider?
I simply want to inc/decrease AC voltage (amplitude)
Thanks
larryd
Quote
AC voltage
That's too wide open.
What exactly are you trying to do?
No technical PMs.
The last thing you did is where you should start looking.
ElCaron
Use a Triac
Usually, you switch with that. The OP thinks he wants alter the amplitude of the voltage.
Deous
I want to regulate AC amplitude between 0-120V - from mains - current about 0.5-4A
Basic idea is to very slowly turn on power devices - don't want to use relay
ElCaron
#5
Mar 19, 2018, 01:16 pm Last Edit: Mar 19, 2018, 01:16 pm by ElCaron
What kind of devices and why?
A lot of devices might not like that at all, especially when electronics are involved.
ted
How slowly - 1 sec. or 1 min, why you need that ?
GolamMostafa
#7
Mar 19, 2018, 01:53 pm Last Edit: Mar 19, 2018, 01:55 pm by GolamMostafa
In AC terminology, there are differences among Amplitude, RMS, Average, and Instantaneous.
Probably, the OP wants RMS of a phase controlled sine wave which could be achieved by a TRIAC or a back-to-back connected two SCRs.
allanhurst
A common way to achieve slow turn on of a mains device is to use a negative temperature constant resistor in series with the load.
RS, Farnell, Mauser etc keep loads in various current ratings.
Allan
DVDdoug
This is NOT an easy thing to build.   You need something similar to an audio amplifier, but higher voltage & current.    A modern "digital variac" probably uses a switching design (similar to a class-D audio amplifier).
It might be better to buy a regular-old manual Variac.
jremington
Grumpy_Mike
You don't want to use a relay, then good because a relay will not do what you want.
Now why do you think you need to turn on a load slowly? This has all the hallmarks of an X-Y problem.
TomGeorge
How many projects have you got going...
Is this thread related to controlling the Air Con motor?
Can you please tell us your electronics, programming, Arduino, hardware experience?
Tom..... :)
Everything runs on smoke, let the smoke out, it stops running....
ted
Tom..... :)
Good point, maybe compressor motor ?
good luck with results.
Deous
Update: I finished that circuit - fairly simple - 2 n-ch mosfets and 1 npn bipolar with hihg hfe.
Turned out my power mosfets 250v/300A vere too powerful for simple 110V AC and they have too much charge capacity between GDS. For AC mosfets in series are mandatory. I wonder if they make integrated ICs like that
