Topic: Esp8266 + Temp sensor + relay + LCD + battery OR feed of mains (Read 395 times) previous topic - next topic
wolph42
I guess topic tells most. I want to build a board with
- ESP8266 (preferred Wemos D1)
- T sensor
- LCD (shield?)
- 2 buttons (UP/Down)
- Battery feed or more preferred: feed of mains (so an 220v AC--> 5v (or 3.3.?v) DC step down converter)
- 220V relay (shield ?)
I don't mind soldering a bit but preferably I click a couple of shields into one board. Problem is: what to get. I've been scouring over banggood and aliiexpress and there are a LOT of shields and modules and I don't even know whether the above configuration can be attached to the ESP (most likely it will, IRC 6 pins for LCD, 2 for the buttons, one ADC for sensor).
Bottom line I'm overwhelmed by choices and underteached in compatibility, hence I'm looking for advice.
EDIT: to give this topic a bit of focus, here some components I'm thinking off:
(is there a way to wrap hyperlinks on this arduino forum? I can't find any way)
ESP8266:
https://nl.aliexpress.com/item/HLK-PM03-AC-DC-220V-to-3-3V-Step-Down-Buck-Power-Supply-Module-Intelligent-Household/32816632180.html
OLED Shield:
https://nl.aliexpress.com/item/Free-Shipping-0-66-inch-Wemos-Oled-64X48-IIC-I2C-LCD-OLED-LED-Dispaly-Shield-for/32807210516.html
Sensor:
https://nl.aliexpress.com/item/TELESKY-DHT22-digital-temperature-and-humidity-sensor-temperature-and-humidity-module-AM2302/32523611214.html
Relay Shield:
https://nl.aliexpress.com/item/New-Relay-Shield-for-Arduino-WeMos-D1-Mini-ESP8266-Development-Board-WeMos-D1-Relay-Module-Free/32773079321.html
Dual Base Shield:
https://nl.aliexpress.com/item/Free-Shipping-20pcs-lot-RJ45-Network-Jack-Cat5e-Cat-5e-5-Keystone-jack/1680869855.html
Step down convertor
Again, I'm quite clueless whether this is all compatible with eachother and whether these are the best choices.
Thank you!
