Topic: Multidimensional Arrays (Read 782 times) previous topic - next topic
JamesWitney
Hey guys,
I've built a 5*5*5 LED cube, and am trying to write code to control it.
Right now, my code goes:
int values[151] =
  0,
  1,0,0,0,1,
  0,1,0,1,0,
  0,0,1,0,0,
  0,1,0,1,0,
  1,0,0,0,1,
  //End of first layer.
  1,0,0,0,1,
  0,1,0,1,0,
  0,0,1,0,0,
  0,1,0,1,0,
  1,0,0,0,1,
  //end of second layer
  1,0,0,0,1,
  0,1,0,1,0,
  0,0,1,0,0,
  0,1,0,1,0,
  1,0,0,0,1,
  //end of third layer
  1,0,0,0,1,
  0,1,0,1,0,
  0,0,1,0,0,
  0,1,0,1,0,
  1,0,0,0,1,
  //end of fourth layer
  1,0,0,0,1,
  0,1,0,1,0,
  0,0,1,0,0,
  0,1,0,1,0,
  1,0,0,0,1,
  //end of fifth layer
  1,0,0,0,1,
  0,1,0,1,0,
  0,0,1,0,0,
  0,1,0,1,0,
  1,0,0,0,1
  for (int i=21; i <= 52; i++)
    pinMode(i,OUTPUT);
  for (int z = 0; z<=5; z++)
    for (int i = 48; i <=52; i++)
      digitalWrite(i,HIGH);
    digitalWrite(47+z,LOW);
    for (int i=0; i <= 25; i++)
      if (values[i+z*25]== 1)
        digitalWrite(i+21,HIGH);
      if (values[i+z*25]==0)
        digitalWrite(i+21,LOW);
    delay(1);
Basically, it loads a huge array of on/off values, then uses them to control the LED's.
I want to modify the code to take animations, but I keep getting errors - help?
fdufnews
If you don't say what errors it will be difficult to help ;)
robtillaart
int values[151]   defines 6 layers for a 5x5x5 cube why?
Why don't you define the array itself multidimensional:
int  values[5][5][5];  // uses 250 bytes
as you only store one bit in every int better make the type uint8_t (byte)
uint8_t  values[5][5][5] ;   // uses 125 bytes
or even use one byte as an array [0..7]
uint8_t values[5][5];   // uses 25 bytes
OK, you need bitoperators to get/set but these are available - http://www.arduino.cc/en/Reference/BitSet
Rob Tillaart
Magician
It'd be helpful to look in playground first:
http://arduino.cc/playground/Main/InterfacingWithHardware#Output
"cube"
