Topic: Newbie to Arduino Code Help (Read 983 times) previous topic - next topic
Marcio21
Hi To All I Have this circuit it is a lightning trigger and i tried to make the codes for it but they  are not working not even the power led is not powering up can someone help me please
Thank You !!
Code: [Select]
#define SHUTTER_PIN 5
#define LIGHTNING_TRIGGER_ANALOG_PIN 0
#define TRIGGER_THRESHHOLD 5
int lightningVal;
pinMode(SHUTTER_PIN, OUTPUT);
digitalWrite(SHUTTER_PIN, LOW);
pinMode(6, OUTPUT); // Your blink LED
digitalWrite(6, HIGH); // Turn off your blink LED
pinMode(7, OUTPUT); // Your power LED); Your power LED pin
digitalWrite(7, LOW); // Turn on your power LED
Serial.begin(9600); // open serial
lightningVal = analogRead(LIGHTNING_TRIGGER_ANALOG_PIN);
int cmd;
int newLightningVal = analogRead(LIGHTNING_TRIGGER_ANALOG_PIN);
Serial.println(lightningVal, DEC);
if (abs(newLightningVal - lightningVal) > TRIGGER_THRESHHOLD)
digitalWrite(SHUTTER_PIN, HIGH);
digitalWrite(6, LOW); // Turn on your blink LED
delay(1000); // May want to adjust this depending on shot type
digitalWrite(6, HIGH); //Turn off your blink LED
Serial.println("Shutter triggered");
lightningVal = newLightningVal;
ajfisher
I'd suggest that if you're not even getting it powered up properly then something is probably wrong before you even get to the software side. Go back through and make sure everything is set up correctly and test your software with a more basic set up as well so you can see it's supplying the board correctly and then step through each component to check where it might be failing.
cheers
ajfisher
Marcio21
everything is set up correctly !!
Thanks
Magician
#3
Feb 27, 2011, 01:50 pm Last Edit: Feb 27, 2011, 02:01 pm by Magician Reason: 1
Where is + input terminal connected?
Have you install a switch and turn it on?
Marcio21
9v battery         on off switch
Magician
Code: [Select]
pinMode([color=red]6[/color], OUTPUT); // Your blink LED
pinMode([color=red]7[/color], OUTPUT); // Your power LED); Your power LED pin
Did you swap a pins? On a board 6 con. to power ind. led,
and 7 con. to trigger release.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
