Loading...
Pages: [1]   Go Down
Author Topic: Comparing ShiftIn Values  (Read 289 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I managed  successfully to built a shift in register with 8 push buttons.
The state of the buttons goes into a variable switchVar1:
Code:
byte switchVar1 = 72;  //01001000
switchVar1 = shiftIn(dataPin, clockPin);
I can show the value of the pressed button doing the following:
Code:
  Serial.println(switchVar1, BIN);
This results in an output between 1 and 10000000.
How can I use the variable switchVar1 in an If- or case-statement?
Thanks in advance,
Schwabinger
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Just like any other variable. The source of the value stored in the variable is completely irrelevant.
Or, perhaps I don't understand your question, or you are not asking the right question.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
ok, let me be more precise:
If I do understand correctly, pressing the first button sends a 00000001 to the variable.
Pressing the second sends a 00000010, the third a 00000100 and so on.
I try to evaluate that using the following code:
Code:
  if (switchVar1 == 00000001){
      Serial.println("treffer: 1");
if (switchVar1 == 0000010){
      Serial.println("treffer: 2");
if (switchVar1 == 0000100){
      Serial.println("treffer: 3");
if (switchVar1 == 00001000){
      Serial.println("treffer: 4");
if (switchVar1 == 00010000){
      Serial.println("treffer: 5");
  if (switchVar1 == 00100000){
      Serial.println("treffer: 6");
  if (switchVar1 == 01000000){
      Serial.println("treffer: 7");
  if (switchVar1 == 10000000){
      Serial.println("treffer: 8");
So when I press button 1, i get the result
"treffer 1" and the if-statement does what I expect.
But pressing the second, third ... button, never leads to a result like "treffer 2" or "treffer3".
Any ideas?
Schwabinger
Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Your numbers look binary but they are just integers.
Code:
  if (switchVar1 == [color=red]B[/color]00000001)
if (switchVar1 == [color=red]B[/color]0000010){
etc
If more than one button is pressed you even need to do som bitmagic called masking the bit.
Code:
if ((switchVar1 & B00000010) == B0000010)
or in hex
if ((switchVar1 & 0x01) == 0x01)
etc
Or better use a for loop to check all eight with the bitRead() function
Code:
for (int t=1; t<9; t++)
  if ( bitRead(switchVar1, t) == 1)
    Serial.print("treffer: ");
    Serial.println(t);
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi Robtillaart,
thanks for your help. I did not know about the B for "binary" ....
Now my SlugRadio has eight more station buttons.
Greetings,
Schwabinger
Logged
Pages: [1]   Go Up
Print
Jump to:
