Topic: Comparing ShiftIn Values (Read 707 times) previous topic - next topic
Schwabinger
I managed  successfully to built a shift in register with 8 push buttons.
The state of the buttons goes into a variable switchVar1:
byte switchVar1 = 72;  //01001000
switchVar1 = shiftIn(dataPin, clockPin);
I can show the value of the pressed button doing the following:
  Serial.println(switchVar1, BIN);
This results in an output between 1 and 10000000.
How can I use the variable switchVar1 in an If- or case-statement?
Thanks in advance,
Schwabinger
PaulS
Just like any other variable. The source of the value stored in the variable is completely irrelevant.
Or, perhaps I don't understand your question, or you are not asking the right question.
Schwabinger
ok, let me be more precise:
If I do understand correctly, pressing the first button sends a 00000001 to the variable.
Pressing the second sends a 00000010, the third a 00000100 and so on.
I try to evaluate that using the following code:
  if (switchVar1 == 00000001){
      Serial.println("treffer: 1");
if (switchVar1 == 0000010){
      Serial.println("treffer: 2");
if (switchVar1 == 0000100){
      Serial.println("treffer: 3");
if (switchVar1 == 00001000){
      Serial.println("treffer: 4");
if (switchVar1 == 00010000){
      Serial.println("treffer: 5");
  if (switchVar1 == 00100000){
      Serial.println("treffer: 6");
  if (switchVar1 == 01000000){
      Serial.println("treffer: 7");
  if (switchVar1 == 10000000){
      Serial.println("treffer: 8");
So when I press button 1, i get the result
"treffer 1" and the if-statement does what I expect.
But pressing the second, third ... button, never leads to a result like "treffer 2" or "treffer3".
Any ideas?
Schwabinger
robtillaart
Your numbers look binary but they are just integers.
  if (switchVar1 == [color=red]B[/color]00000001)
if (switchVar1 == [color=red]B[/color]0000010){
etc
If more than one button is pressed you even need to do som bitmagic called masking the bit.
if ((switchVar1 & B00000010) == B0000010)
or in hex
if ((switchVar1 & 0x01) == 0x01)
etc
Or better use a for loop to check all eight with the bitRead() function
for (int t=1; t<9; t++)
  if ( bitRead(switchVar1, t) == 1)
    Serial.print("treffer: ");
    Serial.println(t);
Rob Tillaart
Schwabinger
Hi Robtillaart,
thanks for your help. I did not know about the B for "binary" ....
Now my SlugRadio has eight more station buttons.
Greetings,
Schwabinger
