Topic: Neon Lighting (Read 1 time) previous topic - next topic
baum
I've been looking around ogilumen.com. They sell soviet-style neon lamps and nixie tube. I was thinking about the neon bar graph, but the info sheet isn't very helpful as to power. Should I power it with 125VAC (mains) or 125VDC (boost converter).
Thanks!
johnwasser
"Please send any queries or issues regarding product details to OGI LUMEN at: opensource@ogilumen.com"
The schematic they provide calls for a 0-150v DC regulated power supply.
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
baum
So I'll need to buy their overpriced $60 boost converter. Oh well...
Thanks a lot!
Magician
Any auto converter +12V to AC you can find for $10 around will be even better.
Just open it up and remove 4 transistors bridge, that form AC 60Hz.
baum
Quote
What's that?
Magician
Sorry, my english, the right name "car dc to ac inverter".
You even don't have to remove a bridge, just connect a wire in front of it.
Basically what this device doing, it boost up DC up to +150 - +230V
using transformer , and generate 60Hz AC after that.
http://www.nextag.com/car-dc-to-ac-inverter/stores-html
As you can see 9$ provide 75W, or up to 500 mA HV DC.
baum
baum
Rectify mains voltage w/ HV diodes!
Cheap!
baum
Yes, I understand. but what if I used a 1:1 transformer?
baum
Okey dokey. Thanks a bunch. I think I'll hold off for a while w/ high voltages.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
