Loading...
Pages: [1]   Go Down
Author Topic: Binary counter with 16 Leds  (Read 464 times)
Offline Offline
Newbie
View Profile
Hello
I am following the shiftout tutorial on the site and have completed the counting upto 256 using one 595 shift register. I have added the second 595 and connected a further 8 Led's. This counts up on the Red Led's and down on the Green Led's still using 256, what I want to do is count up using all the Led's. So thats Bin 1111111111111111 = 65535. How would I change the code to achieve this?
Code:
//  Name    : shiftOutCode, Dual Binary Counters                 //
//  Author  : Carlyn Maw, Tom Igoe                               //
//  Date    : 25 Oct, 2006                                       //
//  Version : 1.0                                                //
//  Notes   : Code for using a 74HC595 Shift Register            //
//          : to count from 0 to 255                             //
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
  //Start Serial for debuging purposes
  //set pins to output because they are addressed in the main loop
  pinMode(latchPin, OUTPUT);
  //count up routine
  for (int j = 0; j < 256; j++) {
    //ground latchPin and hold low for as long as you are transmitting
    digitalWrite(latchPin, 0);
    //count up on GREEN LEDs
    shiftOut(dataPin, clockPin, j);
    //count down on RED LEDs
    shiftOut(dataPin, clockPin, 255-j);
    //return the latch pin high to signal chip that it
    //no longer needs to listen for information
    digitalWrite(latchPin, 1);
void shiftOut(int myDataPin, int myClockPin, byte myDataOut) {
  // This shifts 8 bits out MSB first,
  //on the rising edge of the clock,
  //clock idles low
..//internal function setup
  int i=0;
  int pinState;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, OUTPUT);
. //clear everything out just in case to
. //prepare shift register for bit shifting
  digitalWrite(myDataPin, 0);
  digitalWrite(myClockPin, 0);
  //for each bit in the byte myDataOut�
  //NOTICE THAT WE ARE COUNTING DOWN in our for loop
  //This means that %00000001 or "1" will go through such
  //that it will be pin Q0 that lights.
  for (i=7; i>=0; i--)  {
    //if the value passed to myDataOut and a bitmask result
    // true then... so if we are at i=6 and our value is
    // %11010100 it would the code compares it to %01000000
    // and proceeds to set pinState to 1.
    if ( myDataOut & (1<<i) ) {
      pinState= 1;
    else {
      pinState= 0;
    //Sets the pin to HIGH or LOW depending on pinState
    digitalWrite(myDataPin, pinState);
    //register shifts bits on upstroke of clock pin
    digitalWrite(myClockPin, 1);
    //zero the data pin after shift to prevent bleed through
  //stop shifting
Thanks
Geoff
« Last Edit: February 27, 2011, 10:43:09 am by JimiH » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
use  unsigned int  iso  int as it can go to 65535 = 1111 ...1 (16x)
- http://www.arduino.cc/en/Reference/UnsignedInt
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
Thanks that looks like what I need. Any example of how i would incorporate this into the shiftout code?
Code:
//  Name    : shiftOutCode, Hello World
//  Author  : Carlyn Maw,Tom Igoe, David A. Mellis
//  Modified: 23 Mar 2010
//  Version : 2.0
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
  //set pins to output so you can control the shift register
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  // count from 0 to 255 and display the number
  // on the LEDs
  for (int numberToDisplay = 0; numberToDisplay < 256; numberToDisplay++) {
    // take the latchPin low so
    // the LEDs don't change while you're sending in bits:
    digitalWrite(latchPin, LOW);
    // shift out the bits:
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay);
    //take the latch pin high so the LEDs will light up:
    digitalWrite(latchPin, HIGH);
    // pause before next value:
regards
Geoff
Logged
Netherlands
Offline Offline
Tesla Member
View Profile
Read - http://www.arduino.cc/en/Tutorial/ShiftOut - carefully especially the part about red /green leds at the end.
The code should be something like below (not tested)
Code:
  for (unsigned int numberToDisplay = 0;  ; numberToDisplay++)  // it will automagically wrap around ..
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay % 256);  lower byte
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay / 256);  higher byte
be aware 65535 * 500 millisec = 32767 seconds, thats about 9 hours for one loop...
Logged
Rob Tillaart
Offline Offline
Newbie
View Profile
thanks that seemed to work. i was surprised to see the second 595 counts first. so i swapped the LED inputs about. So the second 595 has the first LED's attached and the first 595 has the second LED's. I have the serial monitor printing and it counts up fine.
Just out of interest since I have this setup how would I specify a single number to display like "43690" which would hopefully display 1010101010101010 (On, off, On off etc)?
Regards
Geoff
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Code:
void display(unsigned int numberToDisplay){
// then use
   display(43690);
Logged
Offline Offline
Newbie
View Profile
Thanks Mike I'll give that a go.
Geoff
Logged
Offline Offline
Newbie
View Profile
Wow this doesn't want to go in??
I keep getting a
Code:
"core.a(main.cpp.o): In function `main':
C:\Program Files\ARDUINO\arduino-0022\hardware\arduino\cores\arduino/main.cpp:10: undefined reference to `loop'
Cant see where its gone wrong?
I have read you right Mike Void (display) instead of Void (loop)?
Code:
//  Version : 2.0
//          : Display specified value
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
  Serial.println("reset");
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay % 256);  //lower byte
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay / 256); // higher byte
     display(43690);
Thanks
Geoff
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No you always need a loop, you need the display as well, and you call it anywhere you want. Here I have put it in the setup();
Code:
//  Version : 2.0
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
       display(43690);
void loop(){
Logged
Offline Offline
Newbie
View Profile
Thanks Mike, still learning only had it a week  smiley-red
Geoff
Logged
Pages: [1]   Go Up
Print
Jump to:
