Topic: RGB Matrix: Looking for fet (Read 1 time) previous topic - next topic
cvmeer
Hello,
I am making a board for controlling an RGB matrix.
It`s a Common Anode matrix.
Now i have two questions:
-I want to use 3 595`s to sink current, is that possible?
-I am looking for an SMD fet i can source current with.
The choice is so big i don`t know what to use.
Thanks in advance,
Collin
Grumpy_Mike
Quote
Should be.
You want a P-channel logic FET.
Quote
Sort them by price and pick the lowest price one.
Grumpy_Mike
Quote
But in the datasheet it says things like: Vds -20V
So if that is how much the drain / source will take before it breaks down you are fine. The negative sign means voltage relative to the source, which in a P-channel FET is sitting up at the +5V level, so 0V will be like -5V to the FET, therefore you are well within the range of allowable voltages. The gate threshold should have a -ve value as well.
cvmeer
Thanks allot.
I will read up on transistors and fets  :)
