Topic: Show Compiler Warnings in Arduino IDE (Read 2116 times) previous topic - next topic
ZachRattner
Does anyone know if it's possible to show compiler warnings in the Arduino IDE? It only shows errors with the default configuration.
Thanks,
Zach
Stanley
Hold the SHIFT key while pressing the compile button... all the compiling progress will be shown..
ZachRattner
Here's some representative output of holding down the Shift key while compiling:
Code: [Select]
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/core.a /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/WMath.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-ar rcs /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/core.a /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/WString.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -Os -Wl,--gc-sections -mmcu=atmega328p -o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/ece4994.cpp.elf /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/ece4994.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/leds.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/main.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/mic.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/push_btn.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/state.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/step_motor.cpp.o /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/core.a -L/var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp -lm
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/ece4994.cpp.elf /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/ece4994.cpp.eep
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-objcopy -O ihex -R .eeprom /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/ece4994.cpp.elf /var/folders/5D/5D1wtrJOFcCdyD3dDDlwdk+++TI/-Tmp-/build8918810003090415654.tmp/ece4994.cpp.hex
Binary sketch size: 5730 bytes (of a 32256 byte maximum)
Note that this only shows the files being generated. There are no compiler warnings.
I'm on Mac OS X 10.6.7. Could that have anything to do with the lack of warnings?
Thanks,
Zach
robtillaart
You can see the commands and you can call these in a makefile (or bat file) and adjust warning flags ...
Its not in the IDE but at least you get some warnings..
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
