Topic: Multi function LED controller (Read 2337 times) previous topic - next topic
bzfng
Hello,
I am fairly new at Arduino programming and would like to make a controller the will have 3 effects options.
I have built similar controllers already and use it for a single effect, but would like to incorporate all 3 using a selector switch to choose the effect to run.
The effects are fairly basic, 1- flicker (flame flicker) 2 - Random fade up and down (erratic power) 3 - Strobe.
The controller has a 3 position switch for program selection and 2 pots to vary each effect. The pots will adjust the flicker rate and brightness in mode 1, The frequency of the power disturbance in mode 2 and the on time and off time in mode 3.
I am using the Arduino Pro, the outputs are on the 6 PWM outputs, the pots or on analog inputs 0 and 1 with the selector switch input on 0,1 and 2. The PWM outs are triggering FETs to power the LEDs.
As I said I can run the program as a single effect controller but do not know the best way to combine all three programs together.
Any help would be greatly appreciated.
PaulS
Quote
You could randomly copy bits and pieces from one sketch to another in the hopes that stuff worked. Or, you could post the 3 sketches that work, and we can help you merge them.
Are you able to read the switch to choose the code to run?
fkeel
isnt it just a case of
"if input 1 HIGH then effect 1,
if input 2 HIGH then effect 2
if input 3 HIGH then effect3"?
or am i missing something?
http://embodimentlabs.tumblr.com/
http://paulstrohmeier.info/
bzfng
Thanks for the suggestions. I was using the If then to check the switch but my switch was not working properly.
I have it working now.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
