Topic: micros() help (Read 720 times) previous topic - next topic
vansure
Here is my code.When i is 100,the result of the serial is 96.But When i is 10000,the result is still 96.If i change"a++" into "Serial.print(1)",the result changed. :~
void setup(){
void loop(){
 long i,a;
 for(i=0;i<100;i++){a++;}
 Serial.println(micros());
 exit(1);
Hasan999
Shouldn't you be declaring "a=0" instead of just "a" ?
frank26080115
#2
Feb 28, 2011, 02:40 am Last Edit: Feb 28, 2011, 02:41 am by frank26080115 Reason: 1
probably an optimization issue, the compiler probably knew that "a" was useless and didn't bother running your for-loop, but if you tell it to output "1", then it's forced to actually send that out the serial port, thus the for-loop remained in that case
solve the problem by using a NOP instruction in the for-loop, that's what I would do. Or make "i" volatile.
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
vansure
I got the result after added "Serial.println(a)"and change "a++" into "a+=2".
It proves that the compiler is smart! :)
Thanks for your time!
AWOL
Qualify 'a' as "volatile".
