Topic: Object Pass by reference (Read 790 times) previous topic - next topic
johncc
Fairly new to Arduino, and its been a few years since c++, but....
I get the error messages below.  It doesn't say what line but it seems to be complaining about my transition() function:
Quote
Traffic:-1: error: variable or field 'transition' declared void
Traffic:-1: error: 'TLight' was not declared in this scope
Traffic:-1: error: 'toRed' was not declared in this scope
Traffic:-1: error: 'toGreen' was not declared in this scope
Traffic:-1: error: expected primary-expression before 'int'
Does the arduino version of the compiler support pass by reference, or,  what am I missing...
Thanks!!  Having a great time with this with my nieces!
John
Quote
class TLight {
          private:
      int rP,yP,gP;
      int doubleRedP;
          public:
      TLight(int red, int yellow, int green, int extraRed)
         rP = red; yP = yellow; gP = green; doubleRedP = extraRed;
         pinMode(rP, OUTPUT);
         pinMode(yP, OUTPUT);
         pinMode(gP, OUTPUT);
      TLight(int red, int yellow, int green)
         rP = red; yP = yellow; gP = green; doubleRedP = -1;
      void red()   { set(HIGH, LOW, LOW); }
      void yellow(){ set(LOW, HIGH, LOW); }
      void green() { set(LOW, LOW, HIGH); }
            private:
      void set(int rV, int yV, int gV){
         digitalWrite(rP, rV);
         digitalWrite(yP, yV);
         digitalWrite(gP, gV);
         if (doubleRedP >= 0)
            digitalWrite(doubleRedP, rV);
   TLight t1( 9, 11, 13);
        //TLight t2( 5,6,7);
   void transition( TLight & toRed, TLight& toGreen, int yellowDelay)
      toRed.yellow();
      delay(yellowDelay);
      toRed.red();
      toGreen.green();
   // The setup() method runs once, when the sketch starts
   void setup()   {
      t1.green();
   //   t2.red();
            //transition(t1, t2, 1000); delay(4000);
      //transition(t2, t1, 1000); delay(4000);
AlphaBeta
It's a problem with the IDE, try to author your class and your transition function in a different tab :)
johncc
I'm not sure what the IDE does and doesn't do for me w.r.t. header files, etc.
Now I have Traffic.pde:
Quote
void setup()   {
  t1.green();
  // t2.red();
and TLight.pde in a separate "tab":
Quote
class TLight {
private:
  int rP,yP,gP;
  int doubleRedP;
public:
    rP = red;
    yP = yellow;
    gP = green;
    rP = red;
    yP = yellow;
    gP = green;
    doubleRedP = -1;
  void red()   {
  void yellow(){
  void green() {
private:
  toRed.yellow();
  delay(yellowDelay);
  toRed.red();
  toGreen.green();
And I still get:
Traffic:0: error: 'TLight' does not name a type
Traffic.cpp: In function 'void setup()':
Traffic:4: error: 't1' was not declared in this scope
johncc
Ok, it took me an hour to figure out that I need to include "WProgram.h" in my other file.  So for the sake of posterity, here is the configuration:
Traffic ("Main Tab"):
Quote
#include "TLight.h"
TLight t2( 5,6,7);
  t1.green();
  t2.red();
  toRed.yellow();
  delay(yellowDelay);
  toRed.red();
  toGreen.green();
TLight.h:
Quote
#include "WProgram.h"
class TLight {
    .... etc, as before
Cheers,
John
Coding Badly
Calling core functions in an object constructor can cause serious problems...
Quote
Object constructors are called before the hardware has been initialized.  Add a begin function that initializes the hardware then call begin in setup.  In other words, use Serial as an example of how to do things correctly.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
