Topic: Multiple Vdc Level Shifting... One Common Pull-up? (Read 1 time) previous topic - next topic
aous
Hello,
I am building a simple circuit to sense if three different inputs have +12Vdc on them.  I am using the circuit here: http://arduino.cc/playground/uploads/Learning/Level_shifting_4_arduino.pdf.
I have to sense three different sources of +12Vdc.  I am going to use three 4N33s.  In the circuit at http://arduino.cc/playground/uploads/Learning/Level_shifting_4_arduino.pdf can I use one R3 across each of the 4N33 (i.e. Arduino +5Vdc -> R3 (4k7) -> Paralleled to pin 5 of OK1, OK2 and OK3.  Pin 5 of OK1, OK2 and OK3 to digitalpin 1, 2 and 3 respectively)?
I think R3 is only biasing the input of the digitalpin to high, then when current flows across the opto-coupler, you get a emitter/collector flow thus dropping then input low.  Is this how it works or does R3 serve some other purpose (bias for the transistor??)
Cheers for your help.
retrolefty
No you can't 'share' one resistor for the 3 isolators.
However you can use no resistors if you just enable the internal pull-up resistors for each input pin you use.
do it like this for each input pin used:
pinMode(PinX, INPUT); // set pin to input mode
digitalWrite(PinX, HIGH); // enables the internal pull-up resistor
That will provide the collector current for the optoisolator's output transistor. A digitalRead of LOW means the opto is turned on and a HIGH reading means the opto is off.
Lefty
aous
Ok that makes sense.
So by using the internal pull-up resistor, I can simply hook pin 5 of the optocoupler to an input without the need to use an external +5Vdc?
retrolefty
Quote
Correct
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
