Topic: Making 1000cm^2 boards using EAGLE (Read 7226 times) previous topic - next topic
mmcp42
I may be wrong but I thought that Eagle light was not supposed to be used for manufacturing/production?!?
there are only 10 types of people
them that understands binary
and them that doesn't
liuzengqiang
I only do small production of 100 or so and don't know yet how to panelize with EAGLE. What quantity do you consider production? I don't really know if EAGLE is used in larger productions but I suspect it's true.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
RuggedCircuits
The Eagle Freeware page describes the limitations:
http://cadsoft.de/freeware.htm
Basically, if you make money from your Eagle design then you have to pay for Eagle.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Senso
Easy solution is to switch to Kicad, free and unlimited.
westfw
Quote
EAGLE "freeware" is not supposed to be used for for-profit purposes.  If you're going to sell PCBs, you should pony up the whopping $49 to get the "lite" version that has the same limitations without the non-profit restriction.  It is possible to get well into "manufacturing/production" without being "for-profit" (for instance, in an educational setting), but $50 is cheap moral insurance...
Quote
I doubt your definitions of both "Easy" and "unlimited"... :-(
