Topic: possible to define variable as bit? (Read 1 time) previous topic - next topic
mullenc525
I'd like to switch between 2 states each time a function runs. The best way I can think of doing this is using a bit variable and incrementing it at the end of the function, but it seems one can't define a bit variable in arduino like in C.
Whats the next cleanest way to do this? Incrementing if its 0 and decrementing if its 1 seems pretty cumbersome.
Coding Badly
Code: [Select]
void FlippyFunction( void )
 static boolean state = false;  // or "= true;"
 if ( state )
   // Your code goes here
   // Your other code goes here
 state = ! state;
CrossRoads
similarly,
byte toggle = 0;
then
toggle = 1-toggle; // results in 1-0-1-0-1-0...
mullenc525
neither worked, I'm not sure what exactly is going on but state or toggle were not changing from the value one using serial.println.
I ended up continuously incrementing an unsigned int and using modulus : if (state % 2); state++;
AWOL
Quote
You are using static or global memory, aren't you?
Quote
The only way of getting a single bit is to use bit fields in a struct. If you've only got one such variable, you may as well use a whole byte.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
PaulS
Quote
Neither are we, unless you post some code.
robtillaart
Quote
try: byte state = (state+1) % 2 ;   // 0 <-> 1
Real bitfields are only possible in structs
struct
  byte b:1;
} x;
this defines the var  x.b which is 1 bit in size but still uses 8 bits in memory. Advantage is that if you need more you can do:
struct
  byte a:1;
  byte b:1;
  byte c:1;
} x;
which still uses 1 byte until the sum of the sizes exceeds 8, then it will allocate 2 bytes
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
