Pages: [1] 2   Go Down
Author Topic: Power Down consumption on custom board  (Read 2876 times)
On a custom board, consisting in an Atmega328P and some few passives, I want to check the current consumption of the board in Power Down mode. The only pull-up resistor is the 10k one for the reset circuit. Then there are a number of de-coupling capacitors, that's all. No external crystal used. The atmega is running at 8 MHz internal RC clock, 3.3VDC, BOD disabled.
I've picked some ideas from this post:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285656727/5
So I've created a very simple sketch that puts the atmega in Power Down State:
#include <avr/power.h>
#include <avr/sleep.h>
  byte i;
  // Ensure no floating pins
  for(i=0; i<32 ; i++)
    pinMode(i, OUTPUT);
    digitalWrite(i, LOW);
  // Power-down state
  set_sleep_mode(SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  // Disable functions
  power_all_disable();
  // Enter sleep mode
  sleep_mode();
The issue is that I was hopping to see some few microamps entering the board but I'm finally monitoring 105 uA after entering the Power Down state. Being the circuit so simple I wonder whether I'm entering the low-power state and disabling the functions correctly... On the other hand, I'm now checking the possible leakage through the de-coupling capacitors.
Thanks in advance for your help.
Daniel.
« Last Edit: February 28, 2011, 07:11:29 am by estratos » Logged
www.rocketscream.com
Is there any 3.3 V regulator?
No, I'm directly powering the board from an external power supply.
Thanks.
Dallas
Online Online
Shannon Member
BOD disabled
Disabled by fuse settings?
    pinMode(i, OUTPUT);
There are no definitions for pins 20 through 31 and neither pinMode nor digitalWrite check for an out-of-bounds pin number.  Change the for condition to "< 20".
I vaguely recall that this function does not catch everything.  I can't remember the details so you'll have to search the forum.
Thank you very much for your response.
BOD disabled
Yes
    pinMode(i, OUTPUT);
OK thanks. I copied that piece of code from an sketch written for the Atmega644...
[/quote]
Indeed, removing "power_all_disable()" from the code does not add a single uA to the consumption so I've decided to directly work with the PRR register instead:
  byte i;
  for(i=0; i<20 ; i++)
    pinMode(i, OUTPUT);
  // Power-down board
  sleep_enable();
  PRR = 0xFF;
  // Enter sleep mode
  sleep_mode();
Unfortunately, the above changes still achieve 105 uA in the global consumption. I'm beginning to think that I have a damaged capacitor or a micro-shortcut somewhere on my board...
Thanks again.
Dallas
Online Online
Shannon Member
From the datasheet...
9.11.3 PRR – Power Reduction Register
Bit 0 – PRADC: Power Reduction ADC
Writing a logic one to this bit shuts down the ADC. The ADC must be disabled before shut down.
The analog comparator cannot use the ADC input MUX when the ADC is shut down.
But, if we don't enable the ADC at the 1st place, we don't have to do the above setting right?
Look at 9.10.1 of the datasheet.
Dallas
Online Online
Shannon Member
The ADC is enabled by the core.  I believe init in wiring.c does the deed.
Found it, it is in the wiring file in the core folder. The ADC is enabled by default.
For timers, I think for power down mode, the clock source is not available for it to work.
OK, trying to disable individual functions before stopping each function clock:
  byte i;
    pinMode(i, OUTPUT);
  // Power-down board
  sleep_enable();
  power_adc_disable();
  power_spi_disable();
  power_twi_disable();
  power_usart0_disable();
  power_timer0_disable();
  power_timer1_disable();
  power_timer2_disable();
  PRR = 0xFF;
  // Enter sleep mode
  sleep_mode();
Consumption is still around 105 uA  smiley-cry
Thanks guys!
I've investigated the possibility of "loosing" current through the decoupling capacitors but, even in the worst cases, they might be wasting a total of a few uAmps maximum. I think I'm going to order a couple of DIP-form atmegas in order to do the tests on a breadboard. Then I'll be able to mount only the essential components and measure the current consumption. That will let me discard any programming-related problem.
Dallas
Online Online
Shannon Member
These...
...and this...
  PRR = 0xFF;
...are equivalent.  You still have not disabled the ADC.
You're right!
Let's do then:
  byte i;
    pinMode(i, OUTPUT);
  // Power-down board
  sleep_enable();
  // Disable ADC
  ADCSRA &= ~(1 << ADEN);
  // Power down functions
  PRR = 0xFF;
  // Enter sleep mode
  sleep_mode();
And the result is... less than 0.2 uAmps !!!
Thanks a lot guys for your great help!!
Boston area, metrowest
Online Online
Can you wake up on external interrupt with these power down settings??
Dallas
Online Online
Shannon Member
I think Atmel calls them "asynchronous interrupts".  Off the top of my head (read that as probably with mistakes): pin-change interrupts, USART activity, TWI address match, watchdog interrupt, INTx level.  For the 328, the table in "9.1 Sleep Modes" provides a good overview.
Pages: [1] 2   Go Up
