Topic: Quick help with EEPROM.read() (Read 769 times) previous topic - next topic
Bebbetufs
Feb 28, 2011, 02:56 pm Last Edit: Feb 28, 2011, 02:58 pm by Bebbetufs Reason: 1
Code: [Select]
//____________Defining global variables________________________________________
   boolean pType = 0; //Choose BAR = false /psi = true =!0
//____________Reading values from eeprom_______________________________________
pType = EEPROM.read(0);
void saveSettings()
      if (flagChanges = 1) //Only save if necassary!
            EEPROM.write(0,pType); //Pressure units
             lcd.clear();
             lcd.setCursor(2, 1); // set the cursor to column 3, line 0
             lcd.print("NO CHANGES MADE!");
             lcd.setCursor(4, 2); // set the cursor to column 3, line 0
             lcd.print("EXITING MENU");
             menu.moveUp(); //EXIT up one level
Causes error message
Quote
expected constructor, destructor, or type conversion before '=' token
I can't figure out what's causing this.
robtillaart
If you post your whole code we can reproduce the feature.
I assume  pType = EEPROM.read(0);  is causing the error as it is done outside a function ...
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
Bebbetufs
#2
Feb 28, 2011, 03:31 pm Last Edit: Feb 28, 2011, 03:33 pm by Bebbetufs Reason: 1
Sorry.
Had to attach it as zip.
It is too big for the forum.... but, you are right. I need to put it inside "void setup()"
James C4S
Code: [Select]
is not the same as
Code: [Select]
if (flagChanges == 1) //Only save if necassary!
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
