Topic: Arduino 101 cant read MS5607 Altimeter Module on I2C? (Read 2628 times) previous topic - next topic
OhItsTarik
Apr 03, 2018, 09:38 pm Last Edit: Apr 03, 2018, 09:41 pm by OhItsTarik
Hey! Somewhat inexperienced when it comes to coding but i can work my way around most stuff. I just want to get output from this MS5607 module. I tried using the I2C scanner from the arduino playground (https://playground.arduino.cc/Main/I2cScanner) and used the example code from the MS5607 library (https://github.com/Schm1tz1/arduino-ms5xxx). Both of them couldnt detect the module. What do you guys think the error is?
My connection with the module and the Arduino 101 board (respectively) is as follows:
Altimeter:     Arduino 101:
VIN              3.3V (also tried 5V, MS5607 can use from 3.3V to 6.5V)
GND             GND
SDA             SDA (Also tried SCL, and A4/A5)
SCL              SCL (Also tried SDA, and A4/A5)
What else can I try? I'll also connect this to my Arduino Uno board later today and see if it's maybe a problem with my board.
