Topic: can't get it work right! (Read 1 time) previous topic - next topic
latif
i can't get the data displayed right in the screen!!
i tried to find out what's wrong but i couldn't, i took the temp/humidity code somewhere from the net and modify it to my code!
Code: [Select]
#include <LiquidCrystal.h>  // include the library code:
LiquidCrystal lcd(12, 11,10, 5, 4, 3, 2);  // initialize the library with the numbers of the interface pins
int backlight = 13;        // tun the back light of lcd on.
int voltage = 0;         // the volatge value to compare with the sensor value.
int pump = 6;             // select the pin for the pump.
int dataPin = 9;
int sckPin = 8;
int sensorOne = A0;        // select the input pin for the first sensor.
int valve = 0;             // the pin for the first sensor valve.
int sum=0;                 // the sum of the sensorOne reading.
int average =0;            // the average reading for sensorOne reading.
int sensorTwo = A1;        // select the input pin for the second sensor.
int valve2 = 1;            // the pin for the first sensor valve.
int sum2=0;                // the sum of the sensorTwo reading.
int average2=0;            // the average reading for sensorTwo reading.
int temp = A2;             // select the input pin for the temp sensor.
int humidity = A3;         //  humidity sensor.
int maxTemp = 85;          // the maximum temperature.
int valve3 = 7;            // the pin for the first sensor valve.
int sum3=0;                // the sum of the sensorTwo reading.
int average3=0;            // the average reading for sensorTwo reading.
void resetSHT()
 pinMode(backlight,OUTPUT);
 pinMode(dataPin,OUTPUT);
 pinMode(sckPin,OUTPUT);
 shiftOut(dataPin, sckPin, LSBFIRST, 255);
 digitalWrite(dataPin,HIGH);
 for(int i = 0; i < 15; i++){
    digitalWrite(sckPin, LOW);
    digitalWrite(sckPin, HIGH);
    digitalWrite(backlight,HIGH);
//Specific SHT start command
void startSHT()
 digitalWrite(sckPin,HIGH);
 digitalWrite(dataPin,LOW);
 digitalWrite(sckPin,LOW);
void writeByteSHT(byte data)
//  digitalWrite(dataPin,LOW);
 shiftOut(dataPin,sckPin,MSBFIRST,data);
 pinMode(dataPin,INPUT);
 //Wait for SHT15 to acknowledge by pulling line low
 while(digitalRead(dataPin) == 1);
 digitalWrite(sckPin,LOW);  //Falling edge of 9th clock
 //wait for SHT to release line
 while(digitalRead(dataPin) == 0 );
 //wait for SHT to pull data line low to signal measurement completion
 //This can take up to 210ms for 14 bit measurments
 int i = 0;
 while(digitalRead(dataPin) == 1 )
   i++;
   if (i == 255) break;
   delay(10);
 //debug
 i *= 10;
// lcd.print("Response time = ");
// lcd.println(i);
//Read 16 bits from the SHT sensor
int readByte16SHT()
 int cwt = 0;
 unsigned int bitmask = 32768;
 int temp;
 for(int i = 0; i < 17; i++) {
   if(i != 8) {
     temp = digitalRead(dataPin);
     lcd.setCursor(0,2);
     lcd.print(temp,BIN);
     cwt = cwt + bitmask * temp;
     bitmask=bitmask/2;
   else {
 //leave clock high??
 lcd.println();
 return cwt;
int getTempSHT()
 startSHT();
 writeByteSHT(B0000011);
 return readByte16SHT();
int getHumidSHT()
 startSHT();
 writeByteSHT(B00000101);
latif
Continue ...
Code: [Select]
 pinMode(backlight, OUTPUT);
 digitalWrite(backlight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
 lcd.begin(20, 4);
 lcd.clear();
 lcd.setCursor(0,0);
 lcd.print("     Welcome to");    // change this text to whatever you like. keep it clean.
 lcd.setCursor(0,1);           // set cursor to column 0, row 1
 lcd.print("Senior Project ELET440");
 lcd.setCursor(0,2);
 lcd.print("Probe Auto-Watering.");
 lcd.setCursor(0,3);
 lcd.print("Starting.");
 delay(2000);
 lcd.setCursor(9,3);
 lcd.print(".");
 delay(2000);
 lcd.setCursor(10,3);
 lcd.print(".");
 delay(2000);
 lcd.setCursor(11,3);
 lcd.print(".");
 delay(2000);
 lcd.setCursor(12,3);
 lcd.print(".");
 delay(2000);
 lcd.setCursor(13,3);
 lcd.print(".");
 delay(2000);
 lcd.setCursor(14,3);
 lcd.print(".");
 delay(4000);                // Delay 5 seconds.
 lcd.clear();
 delay(150);
 pinMode(pump, OUTPUT);       // declare pump as output.
 pinMode(valve, OUTPUT);      // declare valve as output.
 pinMode(valve2, OUTPUT);     // declare valve2 as output.
 pinMode(valve3, OUTPUT);     // declare valve3 as output.
 Serial.begin(9600);       // initialize serial communication with computer
 resetSHT();
 digitalWrite(pump, LOW);     // turn off the pump.
 digitalWrite(valve, LOW);    //turn off 1st valve.
 digitalWrite(valve2, LOW);   // turn off 2nd valve.
 digitalWrite(valve3, LOW);   // turn off 3rd valve.
 analogRead(sensorOne);      // read sensorOne value.
 lcd.setCursor(0, 1);
 lcd.print("S_1: ");
 lcd.print(analogRead(sensorOne));
 analogRead(sensorTwo);     // read sensorTwo value.
 lcd.setCursor(9, 1);
 lcd.print("S_2: ");
 lcd.print(analogRead(sensorTwo));
 int temp = getTempSHT();
 lcd.setCursor(0,2);
 lcd.print("Temp:");
 lcd.print(temp);
 temp = getHumidSHT();
 lcd.setCursor(9,2);
 lcd.print("Humi:");
 lcd.print(temp);
 if (analogRead(sensorOne) < voltage && analogRead(sensorTwo) < voltage){
   while (analogRead(sensorOne) < voltage &&  analogRead(sensorTwo) < voltage){
   digitalWrite(pump, HIGH);
   digitalWrite(valve, HIGH);
   digitalWrite(valve2, HIGH);
     for (int i=0; i<6; i++){
       lcd.print("S_1: ");
       lcd.setCursor(0,0);
       lcd.print("Pump:ON");
       lcd.setCursor(9,0);
       lcd.print("V1:ON");
      sum += analogRead(sensorOne);
      delay(5000);
    average = sum/10;
    if(average > voltage){
   /////// update the valve condition
      for (int i=0; i<10; i++){
       lcd.print("S_2: ");
       lcd.setCursor(15,0);
       lcd.print("V2:ON");
       sum2 += analogRead(sensorTwo);
      delay(5000);
    average2 = sum2/10;
    if(average2 > voltage){
   lcd.setCursor(0,0);
   lcd.print("Pump:OFF");
   lcd.setCursor(9,0);
   lcd.print("V1:OFF");
   lcd.print("V2:OFF");
 else if(analogRead(sensorOne) < voltage){
   while (analogRead(sensorOne) < voltage){
       lcd.print("S_1: ");
       lcd.print(analogRead(sensorOne),DEC);
       lcd.setCursor(0,0);
       lcd.setCursor(9,0);
       lcd.print("V1:ON");
      delay(5000);
    average = sum/10;
    sensorOne = average;
    lcd.setCursor(0,0);
    lcd.setCursor(9,0);
  else if(analogRead(sensorTwo) < voltage){
    while(sensorTwo < voltage){
       lcd.print("S_2: ");
       lcd.print(analogRead(sensorTwo),DEC);
       lcd.setCursor(0,0);
       lcd.print("V2:ON");
      delay(5000);
    average2 = sum2/10;
    lcd.setCursor(0,0);
  else if(getTempSHT() > maxTemp && getHumidSHT() < 70){
   while (getTempSHT() > maxTemp && getHumidSHT() < 70){
       lcd.setCursor(0, 2);
       lcd.print("Temp: ");
       lcd.print(getTempSHT());
       lcd.setCursor(0,0);
      sum3 += getTempSHT();
      delay(5000);
    average3 = sum3/10;
    if (average3 > maxTemp || getHumidSHT() > 70){
    lcd.setCursor(0,0);
    lcd.setCursor(0, 3);
    lcd.print("the probe is in great condition.");
AWOL
#2
Mar 07, 2011, 10:06 am Last Edit: Mar 07, 2011, 10:19 am by AWOL Reason: 1
There seems to me to be a lot of code there that isn't anything to do with an LCD.
Why don't you concentrate on the bit that does?
Statements like this:
Quote
help no-one.
Code: [Select]
      delay(5000);
    average = sum/10;
Read six values and divide by ten to get the average?
Hmmm.
Probably a good idea to zero 'sum' before you use it too.
Code: [Select]
Missing some braces, perhaps.
Do you see how a lot of your code looks very similar to other bits?
That's usually a clue that you can make your code shorter, which gives the bugs fewer dark corners to hide in, makes your code easier to read, debug and maintain.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
PaulS
Code: [Select]
The aliases A0, A1, A2, and A3 are to be used when using analog pins as digital pins. Is that what you are doing? Are your sensors, whatever they are, digital sensors?
If they are, why are you using analogRead to read them? If they are not, why are you referring to the pins with their digital names?
You should be using 0, 1, 2, and 3, not A0, A1, A2, and A3.
AWOL
Quote
The aliases can be used for both analogue and digital.
latif
I'm using SHT15 temp/humidity sensor, also 2- VG400 for the soil.
AWOL
That doesn't help a great deal.
Ideally, you will have a test program that simulates good readings, and then you can pass them to your LCD drivers to debug your display problems.
gardner
Is your LCD a 1-line 16-character one?
If so, you may find it works if you treat it as a 2-line by 8-character one.
Read this thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1282665074
