Topic: TLC5940 library BasicUse example won't compile ( include not found) (Read 1 time) previous topic - next topic
craiglindley
I'm running the Arduino IDE on a Mac OSX 10.6.6. I've installed the IDE and it works fine. I've been able to compile, download and execute the Blink example successfully.
I got the TLC5940 library as a zip file and extracted the files into a directory I created. The directory structure looks like this:
Documents/Arduino/hardware/libraries/TLC5940
I then go into the IDE and load the TLC5940 BasicUse example via the File menu as follows:
File/Sketchbook/hardware/libraries/TLC5940/BasicUse which brings in the code.
When I try and verify (compile) the code I get a series of errors that I think are caused because the include file was not found.
BasicUse.cpp:50:21: error: Tlc5940.h: No such file or directory
BasicUse.cpp: In function 'void setup()':
BasicUse:55: error: 'Tlc' was not declared in this scope
BasicUse.cpp: In function 'void loop()':
BasicUse:66: error: 'NUM_TLCS' was not declared in this scope
BasicUse:70: error: 'Tlc' was not declared in this scope
So do I have my environment setup wrong?
I can see the include files in the TLC5940 directory just fine.
Thanks for any help you can provide.
Craig Lindley
Coding Badly
These sub-directories should already be in the libraries directory...
Quote
ArduinoTestSuite
EEPROM
Ethernet
Firmata
LiquidCrystal
Matrix
SD
Servo
SoftwareSerial
SPI
Sprite
Stepper
Wire
If they are not present, you are in the wrong place.  You should put the new library in SketchFolder/libraries instead of Arduino/libraries.  Don't forget to restart the IDE when you add or move a library.
