Topic: Feeling stupid (Read 6946 times) previous topic - next topic
Udo Klein
Rob do you use JTAG exclusively under Windows or did you ever do this with Linux? If so - how is this done?
Check out my experiments http://blog.blinkenlight.net
Graynomad
Just Windoze I'm afraid, but for programming I just use AVRdude so I assume that works under UNIX. Presumably Studio is required for debugging.
BTW, I've just posted details about one of my current projects
http://arduino.cc/forum/index.php/topic,53829.0.html
We used some of the same keywords so let me know if I'm doing something too close to your board :)
______
Rob
Rob Gray aka the GRAYnomad www.robgray.com
Udo Klein
Cool - but not even close ;) There are already some open projects out there that are more than close to what I am doing. I might even port one of the open solutions to my board so that there will be immediately a choice to run it open or closed :)
Udo
Space_Tinkerer
Udo,
could you tell me the company that made the boards for you? Could you give a bit more info on that? Like you gave them only the blueprints, or did you also give them the components? For 140 euro each board they must have done everything from scratch right??
P.S. Good luck with the product!
Udo Klein
The company is http://www.pcb-pool.com/. I gave them my eagle files. I had them order most of the SMD parts and place them. I provided two special SMD parts that they did not have to order. I hand soldered the TTH parts (display, switches, connectors).
Worked much better than expected and was pretty easy following their guidelines. The quality is very good. All mistakes are due to mistakes that I made in the eagle files.
Udo
Space_Tinkerer
Thnx for the info!
So basically they built the PCBs and soldered all SMD parts, right? 700 euros seem expensive though for 5 boards...
Udo Klein
Why do you think it is expensive? Especially without knowing how many parts and how expensive the parts?
Space_Tinkerer
Sorry I misread, I thought you paid that just for the pcb and the soldering...
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
