Loading...
Pages: [1]   Go Down
Author Topic: driving servo motors with a clock  (Read 172 times)
Offline Offline
Jr. Member
View Profile
i am workin on a clock drived by many servos, i will need 9 for the hours, 14 for the minuts ( 5 for the decimal digits and 9 for the others ) , and they will be 2 marks on every servo ( one at the 0 degree and one on the 45 degree ), so lets say the time is
"6:45" then 6 of the 9 servos ( for the hours ) will be on 45 Dg, while the others on 0 , and 4 of the 5 will be active ( for decimals ) and then 5 out of 9.
Code:
// include libraries
#include "Wire.h"
#include "Servo.h"
Servo  hour_servo1
Servo  hour_servo2
Servo  hour_servo3
Servo  hour_servo4
Servo  hour_servo5
Servo  hour_servo6
Servo  hour_servo7
Servo  hour_servo8
Servo  hour_servo9
Servo  hour_servo10
#define DS1307_I2C_ADDRESS 0x68
// defining variables
int realhour = 0;
int hours = 0;
int minutes = 0;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
void setDateDs1307(byte second,byte minute,byte hour,byte dayOfWeek,byte dayOfMonth,byte month,byte year)
  Wire.beginTransmission(DS1307_I2C_ADDRESS);
  Wire.send(0);
  Wire.send(decToBcd(second));    // 0 to bit 7 starts the clock
  Wire.send(decToBcd(minute));
  Wire.send(decToBcd(hour));
  Wire.send(decToBcd(dayOfWeek));
  Wire.send(decToBcd(dayOfMonth));
  Wire.send(decToBcd(month));
  Wire.send(decToBcd(year));
  Wire.send(0x10); // sends 0x10 (hex) 00010000 (binary) to control register - turns on square wave
  Wire.endTransmission();
void getDateDs1307(byte *second, byte *minute, byte *hour, byte *dayOfWeek, byte *dayOfMonth, byte *month,byte *year)
  // Reset the register pointer
  Wire.send(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  *second     = bcdToDec(Wire.receive() & 0x7f);
  *minute     = bcdToDec(Wire.receive());
  *hour       = bcdToDec(Wire.receive() & 0x3f);
  *dayOfWeek  = bcdToDec(Wire.receive());
  *dayOfMonth = bcdToDec(Wire.receive());
  *month      = bcdToDec(Wire.receive());
  *year       = bcdToDec(Wire.receive());
// Function to Set time
hour_servo1.attach(1);
hour_servo1.attach(2);
hour_servo1.attach(3);
hour_servo1.attach(4);
hour_servo1.attach(5);
hour_servo1.attach(6);
hour_servo1.attach(7);
hour_servo1.attach(8);
hour_servo1.attach(9);
hour_servo1.attach(10);
  second = 0;
  dayOfWeek = 1;
  dayOfMonth = 24;
  month = 5;
  year = 10;
// Set up the time using the buttons then ->
setDateDs1307(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  getDateDs1307(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
  realhour = int(hour);
  if (realhour==0) // if it is 0000h, that should be 1200h in 12 hour time
    realhour=12;
  if (hour>=13)
      realhour=realhour-12; // convert 24h hours to 12h hours
  hours=realhour*14;
  minutes=minute*3;
    switch(hours) {
      case '1':
        hour_servo1.write(45); // if active set position to 45 degree
        hour_servo2.write(0); // if inactive set position to 0 degree
hour_servo3.write(0);
hour_servo4.write(0);
hour_servo5.write(0);
hour_servo6.write(0);
hour_servo7.write(0);
hour_servo8.write(0);
hour_servo9.write(0);
hour_servo10.write(0);
      case '2':
      case '12':
  delay(100);     // servos need time to move
    switch(minutes) {
      case '1':
      case '2':
      case '60':
  delay(100);
1 ) - i have problems setting time with buttons ... i cant figure out how to do it ?
2 ) - As you can see the case method will be quite long, is there another way to do it ? i was reading about arrays, but can anyone show me an example, because i am not sure how to do it neither.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Time to learn about arrays of objet pointers.  Something like this will do the whole hours case statement:
Code:
Servo *hourServos[] = {hour_servo1,  hour_servo2,  hour_servo3,  hour_servo4,  hour_servo5,  hour_servo6,  hour_servo7,  hour_servo8,  hour_servo9,  hour_servo10};
for (i=0; i<10; i++)
    if (i < hours)
        hourServos[i].write(45);
        hourServos[i].write(0);
The tens of minutes and minutes can be done similarly:
minutes / 10 for the ten's digit
minutes % 10 for the one's digit
Logged
Offline Offline
Jr. Member
View Profile
Thank for you help .. reading your answer, i should know that it is beginner stuff ... but okay, i suits my level smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
