Loading...
Pages: [1]   Go Down
Author Topic: Multiple cooling fan control  (Read 1119 times)
Manchester, UK
Offline Offline
Newbie
View Profile
Hello all!
I have recently bought an Arduino uno to help me complete my final year project at university. I am looking to use it in an art installation to control multiple fans, (in a dimmer switch manner), in various places in my degree show space. I am a complete beginnner and have not yet managed to get that far. I was wondering how feasible my idea is and how I begin to go about programming it? If anyone has any recommendations for sites with relevant programming codes that would be amazing. Do I need to buy a servo motor?
Many many thanks, LJ_Blake.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
We need to know more about the fan motors... Voltage power and motor type.
Logged
Manchester, UK
Offline Offline
Newbie
View Profile
Thanks Mark. I am still at a stage of playing with different fans, so am not sure of the motor type, But I would not want them to be any less powerful than a standard 16" oscillating fan which power at approx 45-50w and generally a remote voltage of 220v (sometimes 240). I am hoping to power at least three fans, (obviously from the mains), how feasible is this?!
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
These common mains powered fans use synchronous motors which are not amenable to easy speed control alas...  They are highly inductive so standard light-dimmer modules won't work with them.  They usually come with 3 switchable speeds that work by switching several windings on and off.   See if you can locate ones with continuously variable speed built-in...
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
I replied to your other thread - please don't multi-post in future.
Quote
+1
The standard '3 speed' or single speed fans are not going to be easy to control the speeds of with an arduino.
Logged
Manchester, UK
Offline Offline
Newbie
View Profile
if i didnt control the speed but turned them on and off would it be much simpler?
Logged
Manchester, UK
Offline Offline
Newbie
View Profile
ie. could i use regular fans to do this?
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
With big relays, yes - but note the inductive nature of these motors means a relay rated for motors is needed otherwise the contacts will rapidly be damaged by arcing.
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Perhaps you could get remote controlled sockets as has been discussed many times before and then simply use the arduino to control or emulate the remote control for those sockets. Keeps you away from relays and 220V smiley
Logged
Manchester, UK
Offline Offline
Newbie
View Profile
Ahhh, that sounds much easier. Sorry for the menial questions, but im very much a beginner. Could one arduino remotley control multiple sockets?
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote from: LJ_Blake
Yes - these remote controlled sockets can often control as many as 6 individual sockets from one remote control.
Logged
Phoenix, Arizona USA
Offline Offline
Faraday Member
Where's the beer?
View Profile
WWW
Have you thought about using 12 or 24 VDC automobile (or truck) radiator fans? You could power them off the mains using suitable power supplies (rated for the voltage/amps), and control their speed via PWM using a transistor or FET control. Since they are designed for engine cooling, they will have more than enough power (cfm), and they come in multiple sizes. You can purchase them from automobile and truck part suppliers, as well as wrecking yards (pick-ur-part places, and others).
New or used, they shouldn't cost too much...
 smiley
Logged
Manchester, UK
Offline Offline
Newbie
View Profile
Thanks guys, I'm looking into all of these ideas. Thinking the remote control sockets may be the best option. Any directions to code for use the arduino as a remote control?!
Logged
North Yorkshire, UK
Offline Offline
Faraday Member
View Profile
Quote
Depends on the type you get.
The easiest might be to hack the remote control and use transistors/optos to 'press' the buttons on the remote.
Logged
Offline Offline
Newbie
View Profile
http://www.youtube.com/watch?v=EKjChvta5Bs&feature=player_embedded#at=19
I have been trying to do something similar to yourself(i used rc plane props and drill motors), you can see my results in the vid above. I'd be happy to help if I can.
Logged
Pages: [1]   Go Up
Print
Jump to:
