Topic: An error occurred while uploading the sketch (Read 829 times) previous topic - next topic
Hoffmakl
In the IDE >> a sketch upload >> the sketch "Blink" will be compiled  but not uploaded
In the log:
Sketch uses 9736 bytes (3%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port COM5
PORTS {COM5, } / {COM5, } => {}
Uploading using selected port: COM5
C:\Users\KHoff\Documents\ArduinoData\packages\arduino\tools\bossac\1.7.0/bossac.exe -i -d --port=COM5 -U true -i -e -w -v C:\Users\KHoff\AppData\Local\Temp\arduino_build_979054/Blink.ino.bin -R
after a long time 4-10 min
What can I do?
Environment
Windows10 Pro - Version 1709
Window-Manager COM & LPT
>> Arduino MKR1000(COM5)
   9600 bps
   Databits: 8
   Parität: none
   Stoppbits: 1
   Flow control: none
In the IDE >> preferences.txt
serial.databits=8
serial.debug_rate=9600
serial.parity=N
serial.port=COM5
serial.port.file=COM5
serial.port.iserial=E8728BD85…..
serial.stopbits=1
- no experience with C++, my first steps with MKR1000 -
ballscrewbob
Quickly double press the reset button.
Windows will do a "new hardware found" and put the MKR on a new COM port once you get the timing right for the double press.
AT that point select the new COM port and upload blink.
Be aware also that USB 3.0 type ports are very hit/miss so upload using USB 2.0 ports.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Hoffmakl
Thank you for your help!
After I have connected the USB cable I press 3x the reset button on the MRK.
In the  Device Manager >> I got a new port: COM3 - for the Arduino.
Then I checked the Port: COM in the IDE. It was now COM3.
And the Upload works well.
I use a Z370M-ITXac mainboard.
In the BIOS >> I select Legacy USB Support >> Legacy OS Support for USB 2.0 devices
ballscrewbob
Yes legacy support is another way to do that.
Good thinking !
Just be aware it doesn't always work.
In that is ever the case a good USB 2.0 POWERED hub between the USB 3.0 port and the Arduinos is a very good choice.
