Topic: It does not work powered by 2xAA batteries (Read 1 time) previous topic - next topic
alcapar
I connect to the USB port and everything is fine. In the same place, I fed it with batteries but it is not transmitted to the gateway. Measured 3.2 V.
Any ideas??
cgeorgia
Same here. Seems like we cannot boot it up via the batteries but I could not find any details on that
On the other hand I powered it on via usb, while the batteries were connected to the screw teminal and when I removed the usb cable the system was functioning. But I only had it like this for 1 minute so I am not sure if this is the way to work with batteries and this model.
I am a bit surprised because this is not mentioned in the documentation
dmth
Quite a late reply, but I can run all of my MKRWAN 1300 with a set of AA Batteries.
The devices are booting up and sending LoRa messages, even when a GPS is connected.
Maybe it's the type of battery you are using and their power is slightly to low.
thisismexx
As a beginner on Arduino I had the same issue.
  • running the board on USB worked
  • happily unplugging it and starting it powered by batteries not
The simple reason was: I did not disable the Serial in the sketch
  while (!Serial);
So instead of starting it was waiting to get the connection ....
Commenting those lines and reloading the sketch made it work with batteries as well.
MITEL
  while (!Serial);
One common way to avoid this behaviour, having the same code functioning with and without USB, is:
Code: [Select]
while (!Serial && millis() < 10000);
So, after 10 seconds, if no serial you go anyway :) (and you can forget to comment at every debug cycle).
