Topic: BEGINNERS: Why is GROUND so important? (Read 1 time) previous topic - next topic
lastchancename
There is no secret to 0V / GROUND.
Your power supplies (except in quite unusual situations beyond Arduino) should all have their 0V / GND wires tied together - no other topology makes sense.
This basic understanding of voltages (potential difference) is critical to wiring up *any* electrical circuit.
GROUND is a potential that is  nominally equal to the surrounding electrical 'environment'.
POSITIVE voltages are those 'above' ground.  +12V, +5V and +3V3 are the common positive voltages.
NEGATIVE potentials are those voltages *below* ground potential.
In virtually every 'standard' Arduino project, there are no negative voltages exposed to the developer/user.
Custom boards and interfaces may add 'other' voltages needed by the application.
So the take-away is : BEFORE you burn out boards, or start programming, make sure you have your hardware worked out.
There's no point putting fuel in your car if it doesn't have tyres!
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, know-it-alls, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
Grumpy_Mike
LMI1
Weirdest things I have seen happen when someone forgets to connect grounds together.
SnacksDaily
What do you mean by "connecting grounds together"?
Grumpy_Mike
You take the ground off one system and wire to to the ground off another system.
Clearly you have not read the link I posted.
lastchancename
#5
May 04, 2018, 10:54 pm Last Edit: May 10, 2018, 05:25 am by lastchancename
The two separate systems - the grounds should be connected together with the lowest resistance path available.
