Topic: Motor and sensor (Read 814 times) previous topic - next topic
wvmarle
Code: [Select]
for (int i = 0; i = 0; i++) // we turn the motor
    for (int i = 0; i = 50; i++)
Neither for loop makes sense. You're also re-using variable i in the inner loop.
The second would probably needs to be something like:
Code: [Select]
    for (int j = 0; j < 50; j++)
The first... just doesn't make sense.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
Swaggydogy
maybe but in try here to make a constant value fo speed for the motor
Robin2
But it make error because i think the:
Code: [Select]
for (int i = 0; i <= 50; i++)
doesn't work with the 'if'
Of course it won't. Why would you expect the code for a FOR loop to work with an IF statement.
Please put this project to one side for the moment and, as I suggested in Reply #22, take some time out to learn the basics of programming.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
Swaggydogy
Hi everyone good news i edit the code and it's gave me no error.
Code: [Select]
const int buttonPin = 2; // broche du capteur PIR
const int ledPin = 12; // la LED du Arduino
int buttonState = 0; // etat de la sortie du capteur
int pinMoteur = 7; // broche pour le moteur
  pinMode(ledPin, OUTPUT); //la broche de la LED est mise en sortie
  pinMode(buttonPin, INPUT); //la broche du capteur est mise en entree
  pinMode(pinMoteur,OUTPUT);
  if (pinMoteur = LOW) // Si le moteur n'est pas lancè
    digitalWrite(ledPin, LOW); // la LED est éteinte
    digitalWrite(pinMoteur,HIGH);//moteur se lance
    delay(10);
  if (pinMoteur = HIGH) //si le moteur est lancé
    buttonState = digitalRead(buttonPin);//lecture du capteur
    if (buttonState == HIGH)
    digitalWrite(pinMoteur,LOW); //le moteur s'arrête
    delay(10);
    digitalWrite(ledPin, HIGH); //on allume la LED
But the motor don't rotate...
wvmarle
Your if statements are wrong. Use == instead of =. That also should probably be a digitalRead().
pinMoteur should contain your pin number, so you don't want to assign a new value to it (which is what you actually do in those if statements). This can also be made const, had you done so  the compiler would have complained. Also make those variables a byte, saves some memory.
Code: [Select]
const byte buttonPin = 2; // broche du capteur PIR
const byte ledPin = 12; // la LED du Arduino
byte buttonState = 0; // etat de la sortie du capteur
const byte pinMoteur = 7; // broche pour le moteur
  if (digitalRead(pinMoteur) == LOW) // Si le moteur n'est pas lancè
    delay(10);
  if (digitalRead(pinMoteur) == HIGH) //si le moteur est lancé
      delay(10);
Swaggydogy
dear wvmarle i can't thank you enought.
The simulation work and it's what i need.
And again i can't be enough grateful to you.
Just one last thing...
Can you tell me what the difference between digitalRead and digitalWrite?
And also what the difference about '=' and '=='?
wvmarle
One reads the status, teh other wri
One reads the pin status, the other sets it. Tutorials on both commands on this site.
Quote
The first is an assignment, the second a boolean comparison. Read up on those, it's basic programming.
Swaggydogy
thank very much for you're help.  :)  :)  :)  :)
