Loading...
Pages: [1]   Go Down
Author Topic: Change LED display with push button  (Read 921 times)
Offline Offline
Newbie
View Profile
Hello
I have 16 LED's and 2 595 shift registers connected I can send a display value to the LED's, 1010101010101010 etc. I have just connected a pushbutton switch which turns on LED 13 if the number of button pushes is dividable by 4. I want to specify two display values which are selectable by the number of button pushes. ie if its dividable by for display 1010101010101010 else display 1111000011110000.
Code:
[shadow=red,left]const int  buttonPin = 2;    // the pin that the pushbutton is attached to
const int ledPin = 13;       // the pin that the LED is attached to
// Pushbutton int's Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
//LED 595 shift int's
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
  //Pushbutton Setup
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  // initialize the LED as an output:
  pinMode(ledPin, OUTPUT);
  // initialize serial communication:
  //LED 595 shift setup
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  //display(43690);
  display(48982);
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button
      // wend from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes:  ");
      Serial.println(buttonPushCounter, DEC);
    else {
      // if the current state is LOW then the button
      // wend from on to off:
      Serial.println("off");
  // save the current state as the last state,
  //for next time through the loop
  lastButtonState = buttonState;
  // turns on the LED every four button pushes by
  // checking the modulo of the button push counter.
  // the modulo function gives you the remainder of
  // the division of two numbers:
  if (buttonPushCounter % 4 == 0) {
    digitalWrite(ledPin, HIGH);
    // Put some code here to display(43690);
   digitalWrite(ledPin, LOW);
   // Put some code here to display(48982);
void display(unsigned int numberToDisplay){
    digitalWrite(latchPin, LOW);
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay % 256);  //lower byte
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay / 256); // higher byte
    digitalWrite(latchPin, HIGH);
[/shadow]
Regards
Geoff
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
What  is your question?
You seem to have a function to shift out the needed data.
Call it with data of 0xAAAA & 0xF0F0.
Altho I would call it like this per the reference page for shiftout()
// shift out highbyte
shiftOut(dataPin, clock, MSBFIRST, (data >> smiley-cool);
// shift out lowbyte
shiftOut(data, clock, MSBFIRST, data);
Not sure wht %256 & /256 is doing for you.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
Thanks crossroads, yes your right about the 256, this code came from another sketch I was using and somehow never affected my new sketch. Copy & Paste is too easy  smiley-red, I'll clean it up. Basically when I press a switch I want the LED pattern to change from one to the other. ie
Code:
Regards Geoff
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Still not sure what your question is?
Do you want code for
in which case it is
display(43690);
Given you have a display function in the earlier code.
Logged
Offline Offline
Newbie
View Profile
Thanks Mike, I was 90% there.
Sorted it now and cleaned the code up (thanks crossroads) so here is the code, I have specified three different patterns using 16 Led's. This code cycles through them using a push button.
Code:
//Using a pushbutton to cycle through various LED patterns
//16 LED's are used with two shift registers, used Arduino SHIFTOUT as a start
int latchPin = 8;
int clockPin = 12;
int dataPin = 11;
  //Pushbutton Setup
  //display(43690);
  display(48982);
    else {
  //Pressing the button once lights pattern 1, twice pattern 2 etc etc
switch (buttonPushCounter) {
    case 1:
       display(43690);
    case 2:
   display(48982);
     case 3:
           display(58163);
    default:
buttonPushCounter = 0;   // Resets counter to 0 so we can cycle through 1, 2, 3 again
   display(58163);
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay);  //lower byte
    shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay); // higher byte
regards
Geoff
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
You're missing something here:
The shifout example shows:
shiftOut(dataPin, clock, MSBFIRST, (data >> 8 );   the 8 ) got turned into smiley-cool above
You probably don't notice if your two bytes are the same: 0xA0A0 & 0xF0F0
I find using the decimal equivalent not terribly useful.
Logged
Pages: [1]   Go Up
Print
Jump to:
